Old 04-30-2018, 08:19 PM   #1
alain h's Avatar
Temperature setting on the fridge
Well in my new 224 vibe
I was told the setting is by moving the plastic piece on the back fins of the fridge up and down
Itís just a plastic piece ??????
There is a white probe on the bottom of the fridge
It that the sensor????
alain h is offline   Reply With Quote
Old 04-30-2018, 08:28 PM   #2
cavie's Avatar
The probe is the sensor called a thermistor. The plastic thing is the holder. They must be together and attached to the fins. Mine is about 3/4 down from the top of the fins. It is mounted on the right side.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 04-30-2018, 08:38 PM   #3
Flybob's Avatar
Sensor should clip into the plastic slide.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 04-30-2018, 08:46 PM   #4
alain h's Avatar
Thanks now that make sense
Old 05-01-2018, 01:49 PM   #5
Which way makes it colder, up or down?
minilite2507s is offline   Reply With Quote
Old 05-01-2018, 02:06 PM   #6
Blackrock's Avatar
Up for colder - mine jiggled down on a rough washboard road in Alaska and warmed up.
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Blackrock is offline   Reply With Quote
Old 05-03-2018, 05:38 AM   #7
country ham's Avatar
Articca adjustable thermostat. look on you tube for this thermistor I really like this one https://www.ebay.com/itm/Dometic-The...wAAMXQueRRYoEB this may help. I like my temperature to be at 32/33 the fin model would go to 38 deg. replaced it with the articca and I am at 32. Had a post on 6-21-2013 on this subject with great pictures.
2015 F250 6.7 DIESEL
2013 CHAPARRAL 280RLS
country ham is offline   Reply With Quote
Old 05-03-2018, 05:58 AM   #8
RSchleder's Avatar
I actually put a small squeeze clamp on my plastic clip and it holds it in place even during long trips and bumpy roads. Never have to worry about the clip sliding/moving and the refrig warming up!
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 05-03-2018, 06:08 AM   #9
Articca adjustable thermostat the only way to go
Old 05-03-2018, 10:27 AM   #10
alain h's Avatar
Will look in Articca
Old 05-03-2018, 10:33 AM   #11
Fulltime family RVer
Here's a different website for it:
https://www.snip-the-tip.com/
fridge
