Old 03-30-2018, 03:23 PM   #1
alain h's Avatar
Tv mount
We just purchase a 2018 forest river extreme Click image for larger version
ID:	166629vibe 224 rls
We would like to install a 32 in tv above the entertainment center
Should we use a wide or a narrow tv mount on the wall
Anyone knows if there is a special studs in that area for a tv mount
Alain
alain h is offline   Reply With Quote
Old 03-30-2018, 03:31 PM   #2
Grapelape's Avatar
Originally Posted by alain h View Post
We just purchase a 2018 forest river extreme Attachment 166629vibe 224 rls
Alain
Great question! We just brought home a 2018 Wildwood and were told by the dealer that there is one stud running down the middle of the wall. Iíll be following your post to see what others say.
Chris
Grapelape is offline   Reply With Quote
Old 03-30-2018, 05:07 PM   #3
alain h's Avatar
Old 03-30-2018, 05:18 PM   #4
cavie's Avatar
Home Depot stud finder. Look for staples holding paneling to the studs.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 03-30-2018, 05:53 PM   #5
brad10281's Avatar
That area should be backed by plywood for the mount. You shouldn't need to locate studs. Obviously I have no idea how your particular RV is built but my entertainment center and the wall in the bedroom are both backed with plywood for TV mounts. You should be able to tell just by pushing or banging on that area, if it's solid then it's likely backed by plywood. Just use short fully threaded lag screws. I'm sure others will chime in if I'm giving out bad advice.
Brad & Gail
2014 Chevy Silverado 1500 Z71
2015 Shasta Flyte 255RS
brad10281 is offline   Reply With Quote
Old 03-30-2018, 06:04 PM   #6
alain h's Avatar
Ok thanks
mount, tv mount
