Old 06-01-2019, 10:20 AM   #1
TV mount
I have a 2017 Vibe Extreme Lite and canít figure out how to get the corner TV off the fixed wall mount. All connections and inputs are not accessible. Does anyone know the secrect to release the tv plate from the wall plate. It seems to be some kind of wedge system, but there is no apparent way to release a catch if it even has a catch!
Call me frustrated!
hooblet is offline   Reply With Quote
Old 06-01-2019, 10:42 AM   #2
SeaDog's Avatar
Welcome to the forum its a great place to get your questions answered. Some do have a V shaped wedge that requires considerable force to take off. I'm sure someone on the forum will have a much better answer just give it a little time.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 06-02-2019, 02:16 PM   #3
Thanks Seadog
Hope I get some advice. Donít want to break TV
Old 06-02-2019, 03:03 PM   #4
CincyGus's Avatar
If it's a flat mount, most just lift off out of the top of the wedge. Most with a catch have some sort of small chain to pull to release. Can you get a pic of what you can see and post?
2020 Chevrolet 2500 LTZ, 2019 Forest River Wolfpack 23Pack15, 2014 EZGO Golf Cart.
CincyGus is online now   Reply With Quote
Old 06-02-2019, 03:14 PM   #5
Usually Confused Member
emm-dee's Avatar
Hold onto the bottom corners of the TV. Gently rock each side end in an up/down motion while applying a very, very firm upward pull.
2018 Forester 3051S (aka Clyde)
2015 Wrangler Toad (aka Bonnie)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Old 06-03-2019, 09:34 AM   #6
I can barely see in back of TV. Canít get a picture. Plate attached to TV is twice as large as wall plate. It must be ďfrozen ď in place. Guess Iíll continue with lifting/rocking. Persistence!
Old 06-03-2019, 09:43 AM   #7
Dont know if I can put this into understandable words....
If the arm has a joint (elbow) like mine, there is a hex bolt that holds this joint together. You can remove this bolt and separate at that jjoint, getting the TV out of the way (with half the bracket). Then left with just part of the bracket to work with.
gbaldwin is offline   Reply With Quote
Old 06-03-2019, 10:06 AM   #8
Most wall mounts in a R/V look like this if they do not articulate. (move for different viewing angles) To remove they simply lift upwards. If stuck, the rocking motion helps.
Days Camped: '17=30 '18=51 '19=58 '20=83
mount, tv mount
