If you have an idea of the area of the leak you may be able fix it without pulling the complete section of coporlast down. cut a U (bottom of the U facing forward) shaped flap in the area you need to inspect/repair. when you are done close the flap and I like to use foil tape to seal it. good luck
Retired Navy
2016 Flagstaff 26 FKWS
