Old 01-28-2019, 03:49 PM   #1
USB ports not working
I have a 2016 272 bhs. There is the charging hub with a 12v plug and 2 usb plugs in the shelf at the head of the bed. My 12 volt plug works fine, but the 2 usb plugs are not working. Does anyone know if this is a fuse issue or what it could be?
dnichs is offline   Reply With Quote
Old 01-28-2019, 04:13 PM   #2
Lacey's Spring, AL
formerFR's Avatar
all 12v/usb outlets are not necessarily run by the Vehicle's battery, but may be powered by the HOUSE battery(s)... even if they are right next to each other.
also, some devices don't operate/function properly with some usb outlets, depending on whether they are usb, usb2, usb3 types, etc. I have several iphone 'brick' usb plugs that won't work since they are not compatible with my 'newer' phone, and sometimes it's just because the usb outlet is not 'up to date' with that version of power.
The Turners
'14 Thor Palazzo 33.3 compact diesel
KingTailgater2 Dish, 100w/5amps roof SOLAR, BlueOx, 100,000+mi since '14... US, Alaska, and Canada... from GA, then NC, now N AL : )
formerFR is offline   Reply With Quote
