Old 03-01-2020, 11:56 AM   #1
Toolman_GA's Avatar
Vibe 2017 268rks slide Flex guard rubbing on tire
I noticed that the flex guard doe my slide wiring was rubbing on my tire after I had a blowout. Checking to see if this is something anyone has seen before and do I simply need to put a new one on or is there a way to improve it so that it helps it to be supported?Click image for larger version
ID:	224221Click image for larger version
Steve/Pam - 2011 GMC 2500 HD Denali, 6.0L. Not quite yet retired but getting there... USN - sorry, no more free rides for my USMC buddies....
Kennesaw, Georgia
Toolman_GA is offline   Reply With Quote
Old 03-02-2020, 08:55 AM   #2
SeaDog's Avatar
I would strap it up ensuring there is slack for the slid to move without pulling on the wires
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 03-03-2020, 02:46 PM   #3
Toolman_GA's Avatar
Thanks. I did use a small bungee chord to hold it up from bouncing but I have to remember/add to my checklist to remove it before I open the slide. I suspect it may have gotten deformed by the tire blowout flapping against it. Probably best to replace it.
Kennesaw, Georgia
Old 03-15-2020, 09:11 AM   #4
Itís tin. Cut it or screw in a support rod.
bjaspud is offline   Reply With Quote
slide, tire, vibe
