DW and I were trying to use the black tank flush this morning prior to leaving the camping spot, hooked up the hose, no go, the water seemed to be restricted prior to entering the TT, hose accepted water but none was flowing into the black tank, confirmed by opening the dump valve, no water exited the tank. It was at this point I decided to read the caution sticker on the side by the BTF connection, it says something about the "Fullway Termination Valve must be in the open position", where the heck is this valve, a few other FR owners there were as baffled as we were. Any ideas? My choices are you very knowledgable Forum members or calling the dealer in the AM and asking them. TIA.
Never heard of a Fullway Termination valve, but the black tank flush is, or should be, plumbed like this:
Here's a pic of the anti-siphon/vacuum breaker valve. It's usually located under the bathroom sink, but could be most anywhere depending on your floorplan. Sometimes these valves stick closed. It also needs to be oriented vertically as shown. Some people have reported them to be plumbed "backwards" (i.e., inlet hose on the outlet and outlet hose on the inlet).
The fullway termination dump valve is the holding tank's dump valve. The one you opened. Unbelievable that no one knew that at your location. It's a sticker installed on virtually every unit, or it should have been, with a black tank clean out installed by the factory. It is of course just a fancy name for the dump valve.
It's just the fancy name for the gate valve you pull to open the outlet. The warning is to prevent an event that is quite dramatic, gross and will leave you wanting to just walk away and change your name. Lol. Look up some videos on YouTube about peeps filling the black tank with the outlet closed and creating a geyser of...urrm..nasty out the toilet or vent on the top of the trailor.
That's what I figured, guess that is engineer speak. How long does it normally take to get water to flow from that tank, we did have the valve open as I said before, no water was coming out, could it be the anti-siphon/vacuum breaker valve sticking or incorrectly installed as Rockfordroo pointed out?
It could be. There's also a backflow preventer right where you connect the hose. It's a one-way valve to prevent flowage back into your hose when you turn the pressure off.
It's very easy to check. Pull off the domed screen at the connection. There will be a small plastic rod sticking out. It should move in and out pretty easily, but might be stuck. You may need a long-nose pliers to grasp it. Be gentle. You don't want to break it, just unstick it if it is stuck.
Larry
It has been my experience that clogging of the spray nozzle inside the tank is most likely the issue. Mind you, not the only cause but more often than not. There has been reports of the valve connected up wrong and also just failing. There typically is no backflow preventer valve at the hose connection input port as has been said. In fact the installation typically says that a backflow preventer should not be in series with the backflow/vacuum breaker in the installed tubing and there is no reason for there to be one.
