Old 03-13-2018, 07:34 PM   #1
Vibe 313bhs
I just bought a new vibe 313bhs. I am parking it at a park for the season. It has 2 grey tanks. Is there a way I can tie these 2 tanks together so I don't have to always hook/unhook the tanks?
jj44 is offline   Reply With Quote
Old 03-13-2018, 09:07 PM   #2
jamie 287QBS's Avatar
There is a sewer hose "y" pipe that you can buy. You will also need 2 other sections of sewer hose. That's what I do since 1 of my grey tanks is all the way under the slide. Google RV sewer hose y. What I'm talking about came up.
jamie 287QBS is offline   Reply With Quote
Old 03-13-2018, 09:09 PM   #3
SlfMdeFam's Avatar
If you post a pic I might be able to help you. I donít have that model but was able to hook both my systems together into one that way I only have one dump outlet now.
SlfMdeFam is offline   Reply With Quote
Old 03-15-2018, 04:53 AM   #4
Thanks for the help!
Old 05-06-2018, 10:10 PM   #5
I had the same issue. Instead of trying to connect both tanks I used 3 inch pvc to hook up the bathroom. Then I bought a cover for the other tank, from camco, with a water hose connection and run a extra water hose, i had, over to the sewer. Just need to drain that tank every so often. Then I lift out the 3 inch and put the water hose in and pull the plug. When I am done I just role the hose up under the camper. For me, it saves alot of brain damage.
virstens is offline   Reply With Quote
vibe
