Vibe android tablet
Hello, Sorry if this has already been addressed somewhere but I have not been able to locate anything other than the connection and range issues with this system.
I have a 2016 279 RBS and it has the tablet with it. When I purchased the unit the awning was very slow in working and after taking it into for repairs the dealer replaced the wire feeding the motor because, "The manufacture used the wrong gauge." The awning works fine when operated by the panel switch however whenever I try using the tablet to run the awning it blows a blade fuse in the wiring (hidden under the pantry not in the power distribution panel).
Anyone ever have this or similar issue? If so were you able to correct it?
Lastly anyone know how to check the slide out's vertical alignment? the kitchen slide out knocks and bangs as it opens now and when I looked at the power gear slide everything looks ok but it looks like the adjustment end of the bracket may have moved. I never thought to take a pic of this when I purchased the unit and I don't remember if it was in a different place before. The reason I think it may have moved is the bracket ends have a couple nuts on a slotted hole and it appears at one time it was in a different location as the paint is scarred and rusted where the nut was tightened to the bracket.
Any help, direction, photo's, videos or advice on either issue would be greatly appreciated.
-Tony
