Old 06-29-2018, 06:05 PM   #1
warped window track
2016 268RKS VIBE
The window track, by the dinette and sofa that the windows slide in is aluminum with a plastic insert track. It warped to the point I had to cut out the plastic track just to get the window to move. Most likely had something to do with the silver bubble insulation that i use to cover the windows in storage. I put the insulation inside behind the shade facing out and I'm thinking that a white surface facing out may not reflect as much heat.
This occurred a while ago but I figured its time to fix it.
Any one know if this plastic track is available?
DByrum is offline   Reply With Quote
Old 08-30-2022, 09:31 AM   #2
Warped window track
Did you ever find a replacement for this? I now have the same issue and don't know how to fix it.
JoeWag is offline   Reply With Quote
Old 08-31-2022, 07:58 PM   #3
no, Forest River sent me some of the same track. It warped after a few months. Still looking for a better solution. Sorry
Old 08-31-2022, 08:28 PM   #4
nvs4602's Avatar
Something like this work?
https://www.rubbertherightway.com/wi...AaArteEALw_wcB
nvs4602 is offline   Reply With Quote
Old 09-01-2022, 08:31 AM   #5
How did you get Forest River to send you some? I think if I had some and then made some changes to how I park the rig, I may be able to avoid this happening again.
Old 09-01-2022, 11:16 AM   #6
Here is what got me some of the same track. It was from LCI. Sold by the foot. This was from 2018.
snip
Check this print, but I believe you need 306605:
RV28274-03; SLIDER TRACK
$0.43 per foot
Retail - $0.63 per foot
To place that order, you can call 574-537-8900 and press option 1 for parts and then 2 for the "speed lane".
Thank you so much,
Ashten Simpson
Call Center Development
w: 574-537-8900 | f. 574-534-7161
Good luck!
Old 08-16-2023, 01:51 PM   #7
did you get your warped window figured out? I'm having the same issue.
mandiegoat is offline   Reply With Quote
window
