Old 10-23-2019, 03:55 PM   #1
Winterizing
I have a 2019 Forest River Vibe 25RK. I am trying to locate the water heater bypass and the water pump. Can anyone direct me to where I might find these? Thanks!
LisaV13 is offline   Reply With Quote
Old 10-24-2019, 08:48 AM   #2
SeaDog's Avatar
Welcome to the forum its a great place to get your questions answered. With some water in your potable water tank (drain later) turn on the pump open a faucet and follow the noise to the pump. The water heater bypass valves are usually located behind (inside the rig) the water heater locate it on the outside and go inside you may have to remove some panels or drawers keep searching good luck
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 10-24-2019, 08:35 PM   #3
Lisav13, I have an 18 Vibe 268RKS. Not sure of the similarities but you should find the valves behind this panel. That is also where the water heater is located. Good luck.
hshaynes is offline   Reply With Quote
Old 10-24-2019, 08:35 PM   #4
Dummy forgot the pic.Click image for larger version
winter
