Old 09-28-2021, 10:31 AM   #1
Mpro326's Avatar
Wiring short after adding Solera Slide Topper to 21 Vibe 25RK
We are new to the group. New to the RV life. Bought a 2021 Vibe 25RK. Everything was working great. I put the Solera Slide topper on with help. After doing so, the slide will not extend. Could a screw from attaching the wall plate gone into the slide out wiring?
Help!
Mpro326
Mpro326 is offline   Reply With Quote
Old 09-28-2021, 10:56 AM   #2
Find your power panel and open the door. Usually, a blown fuse will cause an indicator light to illuminate. If you find one lit, then you probably sent a screw through the wires. Another thing that could happen is incorrect installation of the topper. It could be holding the slide back. Do you hear clicking? Can you hear the motor try to extend the slide?
2012 Cedar Creek 36CKTS Touring Edition
2015 Ford F-350 CC DRW Lariat
Joe_GA is offline   Reply With Quote
Old 09-28-2021, 11:08 AM   #3
Mpro326's Avatar
We do not hear it trying to extend. We hear a click and it sounded as if it were coming from the grounding wire on circuit breaker. Replaced the 30 amp breaker near tongue of trailer. Checked all fuses and breakers inside the RV. I will remove the slide topper wall rail and see if the slide out extends.
Old 09-28-2021, 11:27 AM   #4
D W
D W's Avatar
Your model Vibe appears to have a Lippert Through Frame Slide. The slide motor wiring is underneath inside the frame and not in the overhead. Additionally, the slide 12V lighting for the dinette and sofa is routed underneath up through the slide room via a flexible umbilical cord.
Are you saying that after the topper installation the slide didn't work? No response from the slide when you attempt to move the slide out? As previously stated, I would be checking the fuse first. A picture of your topper installation would be helpful.
2016 Salem 27RKSS
D W is online now   Reply With Quote
Old 09-28-2021, 11:32 AM   #5
D W
D W's Avatar
There should not be any "grounding" on the circuit breaker. The circuit breaker is on the load side (+) of the 12V circuit.
2016 Salem 27RKSS
Old 09-28-2021, 02:37 PM   #6
Dont take the rails off completely. Remove 1 screw at a time if that's what your gonna try.
ard58 is offline   Reply With Quote
Old 10-05-2021, 09:01 AM   #7
Mpro326's Avatar
Thank you all for the advice. Yesterday removed one screw at a time from the slide topper rail. It was one screw that was touching a wire. The screw was black on the end. Cut off the end of the screw to shorten it. Slide works perfectly! Thanks again for the advice!
Mark
Old 10-05-2021, 09:06 AM   #8
Thanks for letting us know what you found.
I'd be tempted to squirt a good bit of caulking in the hole to help insulate the wire where the screw punctured the insulation.
Gotta go campin!
Bama Rambler is online now   Reply With Quote
slide, solera, vibe, wiring
