Are the wires on the street (drivers) side hooked to different wires?
One wire should connect to positive and one to negative. It doesn't matter which wire from the magnet hooks to which pole, but they both have to be hooked up.
Sometimes they use the frame as negative (ground). Look at the drivers side and see how it's hooked up and see if the same wires are available on the passenger side. If there is just one wire on that side the other wire may be routed through the axle and it may have slipped into the axle.
Gotta go campin!
