most cameras are setup as observation cameras and use the trailer lights circuit
NOT the reverse circuit
start by checking for 12v voltage at the 7pin
Number 3 pin to the left of the alignment key way at top of 7 pin
You can also try running a jumper wire from your trailer battery positive
to the #3 pin on the trailer side of the 7 pin
that should give you power to the camera
Tarpon Springs FL
2022 Salem 24RLXL
