Slide not working - More information
Well I do believe that the controller is in the ottoman, with the slide all the way in you can not get to the hatch, the motors are accessible but the screw to loosen them from the outside not accessible with the slide all the way in. Great design, somebody was not using their brain. Couple of options, I have made harnesses to connect to the motors directly and can try to power them to put the slide out assuming they are OK then I can access the hatch and see what the controller says. Have disconnected batteries from the RV and taken all power away for a min or so and have not had any luck.
Slide has been working fine, only thing I did different when I put the slide in and was towing the RV was that I ran the refrig on battery power, when I got to the camping spot 2 hours away the slide would not work, batteries still fully charged (have 400W solar system and RV was connected to car).
Called factory and they have not been much help, a technical person was supposed to get back to me, meanwhile ordered the outriggers to fix sag which the slide is developing. Will also support the kitchen floor soon, sag there will show up soon too. Somebody also lost my screen slide door and been trying to find one and it is only 10" tall which is not standard so have not had any luck, waiting on factory on this too. Not been my week.
Other options is to cut and access hole into the ottoman problem is I don't know how things are installed inside there and don't want to damage any equipment trying to get in there, will run a scope into the area and look at things, regardless this issue has become huge headache.
Don
