I've not had that problem, but when I start my furnace in our 2020 195, I set the desired room temp way high (80 degrees) then let it ignite and run a few minutes before turning the temp down to where I want it. It cycles just fine after that. Might give that a try and see how it works. As my DW found out, make sure the garbage container is not in front of the heater. :-)
Greg 'n Deb
2020 R-POD 195 HRE
'17 Tacoma 3.5L,'07 Tundra 5.7L w/ tow pkgs.
