Old 05-13-2022, 09:55 AM   #1
RPod ceiling speaker replacement
I am wanting to replace the speakers in the ceiling with ones with a better sound. Has anyone located 6 inch speakers with a shallow depth of no more than 1 5/8"? The current speakers are only 1.5" in depth.
Leroy
2017 RPod 178
lgharis is offline   Reply With Quote
Old 05-13-2022, 10:18 AM   #2
nvs4602's Avatar
You can use extender rings. Then install really good speakers.
https://smile.amazon.com/dp/B00ITN4I...ing=UTF8&psc=1
nvs4602 is offline   Reply With Quote
Old 05-24-2022, 11:30 AM   #3
MDF 1" extenders
The plastic ring holes didn't match up with the speakers that I bought. I found some MDF 1" extenders that work great. I first attached the extenders in new holes. Then attached the speakers in separate holes. That means if I ever need to do any maintenance I don't have to remove the extenders, just the speakers.
Old 05-24-2022, 01:53 PM   #4
nvs4602's Avatar
Great!! You should post some pictures.
Old 05-24-2022, 06:31 PM   #5
MDF speaker extender
Picture attached. I don't know why the pic is sideways but it makes no difference.
Old 05-24-2022, 09:52 PM   #6
nvs4602's Avatar
Those worked out pretty good. Did it help sound quality any?
Old 05-25-2022, 09:10 AM   #7
Smile
Yes, sound is much better. It also helps that I found out how to adjust the bass and treble.
Old 05-28-2022, 05:35 PM   #8
I'm interested but a little confused. Where'd you find the extenders you used? Did you cut new holes for the OEM speakers to install these? What'd you do with the original holes? Thanks.
Greg 'n Deb
2020 R-POD 195 HRE
'17 Tacoma 3.5L,'07 Tundra 5.7L w/ tow pkgs.
Dirt Sifter is offline   Reply With Quote
Old 05-28-2022, 05:52 PM   #9
nvs4602's Avatar
You just screw the extenders to the ceiling, then screw the speakers onto them.
https://smile.amazon.com/dp/B07MZKNN...ing=UTF8&psc=1
Old 05-29-2022, 09:57 AM   #10
Got it - Thanks! You used new screw holes - not cut new holes for the speakers. Whew. And thanks for the link to the extenders.
Greg 'n Deb
2020 R-POD 195 HRE
Old 05-30-2022, 12:13 PM   #11
Yes, you are correct. The old speakers had only 3 screws so they would not have worked with the 4 screw speakers anyway. So, I just attached the extenders first. Then attached the speakers to the extenders. I didn't want to have to undo the screws in the ceiling if I need to replace the speakers.
Leroy
replacement
