!!!!I need some help!!!! I have a 2021 RPod 193 and the Factory solar system is not charging my batteries. I checked for power at the solar panel and it’s good. I took the wiring off the controller and I get no power from the solar panel. I’ve checked the trailer for a fuse or breaker and can’t find squat. I replaced the 100a breaker at the front of the trailer, no difference. Does anyone know where the location of the fuse or solar panel would be?
I don't think that there is any fuse between the solar panel and controller. Do the wire colors match up, if not there could be a bad splice along the way. Look closely at the wires on the controller. FR has messed some of the installations up.
2019 Palomino Solaire 147X
2013 Ford F150
I don't know where a splice would be (usually done for a reason in a somewhat accessable spot). What colors are at the panel? What colors at the controller? What controller do you have?
2013 Ford F150
