04-28-2022, 04:14 PM
Sort of stumped on water inlet
Just bought a R-179. The tank water supply inlet is just a twist cap over a 1.25" opening that accepts a hose, but doesn't provide for a secure connection between the hose and the RV FW inlet. Am I missing a part? I'd like to think that it requires a secure hose fitting attached to the RV so that it doesn't make a mess. I'm not talking about the city attachment, just the Fresh water inlet above it. Any help would be greatly appreciated!!! Woops it's a 2017 RPOD-179.
04-28-2022, 04:31 PM
That's pretty standard for fresh water tank fill...just stick the hose in, or use something like this:
https://www.amazon.com/Camco-Shutoff...d=4S084YZLVBP0
2020 Flagstaff Micro Lite 25BRDS SOLD!
2024 Brinkley Z3100
2021 Ford F-350 XLT 6.7L Power Stroke
04-28-2022, 04:34 PM
That is the common type fresh water tank fill used for 40 plus years.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
04-28-2022, 04:35 PM
Originally Posted by Kcoulter
Thanks for sharing. Ordering one of those now!
2021 Surveyor 203rkle
2018 Chevy Silverado
Fastway e2 Hitch
04-28-2022, 04:44 PM
Many Tanks to all
Thanks much for the insights. Just ordered the camco product via amazon....I came out of a Newmar Ventana with all the features and now into a 179....but it's sure nice to know there is quick help out there for me....Many thanks and safe travels to all!!1
04-28-2022, 08:34 PM
You really do not want the fill hose to be tight or snug in that opening. Fill the tank slowly; you want it to breathe… The smaller hole next to the twist cap is the vent that lets air out as the tank fills.
When filling slowly you will hear gurgling sounds from the filler opening and the vent.
If you fill the tank to fast and cause it to swell, it may buckle floor above.
Hope this helps…
Wild Bill
2019 FR Rockwood Mini Lite 2109S
2022 RAM 1500 Bighorn, Quad Cab, 5.7 Hemi, 3.92 gears
To get better, you have to get better at what you are doing to get better.
04-29-2022, 10:59 AM
Hope this helps…
Wild Bill
The tank shouldn't swell unless the vent is plugged, or vent hose is kinked or otherwise restricted. But you are right, you don't want or need the fill hose to be tight in the fill opening.
By the way, don't stand directly in front of the vent, you may take a shower.
04-29-2022, 01:12 PM
For many years, I just used a 1/2 or 5/8 inch hose length (about 12" long) with a female hose connection on it and a ball valve. I screw that to the end of the supply hose and insert it into the trailer fresh water inlet. It has always worked well for me.
04-29-2022, 02:45 PM
What JM said, been working fine for me.
04-29-2022, 04:24 PM
lets try that again:
http://https://www.amazon.com/gp/product/B07JDZMC82/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1"]https://www.amazon.com/gp/product/B07JDZMC82/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1"]http://https://www.amazon.com/gp/product/B07JDZMC82/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1[/URL][/URL]
And:
http://https://www.amazon.com/gp/product/B06XSNPMBS/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&th=1"]https://www.amazon.com/gp/product/B06XSNPMBS/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&th=1"]http://https://www.amazon.com/gp/product/B06XSNPMBS/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&th=1[/URL][/URL]
Dave & Elaine
Brookfield, WI
2021 Rockwood, 2509s, pulled by a 2020 Ford F150 XLT, Super Cab, 3.5L Eco Boost, with 3.55 axle. Electric 10-speed auto trans w/tow mod. Heavy Duty Tow package & integrated trailer brake, 11,700 lb. tow capacity, payload is 1916 lbs. and 145” wheel base. Equalizer 4 point W/D hitch.
