Old 09-13-2020, 02:53 PM   #1
Dbaryk's Avatar
USB
I am not getting any power to the USB ports on the front camp side of the coach. It is a brand new 2021 r-pod 193. What do you think I should be looking for?
Dbaryk is offline   Reply With Quote
Old 09-23-2020, 12:08 PM   #2
Do you have other USB ports on same voltage line? If these are on there own, check fuses, then wiring.
mcarter is offline   Reply With Quote
Old 10-21-2020, 12:18 PM   #3
Dbaryk's Avatar
Turns out that the wire that should have brought power from USB port to the other port on the opposite side of the coach was cut and a small length of it was attached in a loop at the port with power. I was able to find the end of the wire going to the un-powered port and connect it correctly. Problem solved. Chalk it up to a technician who lost his (or her) focus during the install.
Old 10-21-2020, 01:17 PM   #4
On our 2020 14fk, we lost power on the two stand alone USB ports, near the main switch panel. It may be a loose connector or a blown fuse. The ports previously worked, so something changed.
Forest River Flagstaff e-pro 14fk
Ford Escape Turbo
Sarahcat is offline   Reply With Quote
Old 10-21-2020, 01:25 PM   #5
bikendan's Avatar
The OP solved the problem in the post above yours.
Old 10-21-2020, 01:52 PM   #6
Time stamps on posts only a minute apart. Probably both typed at the same time and one arrived sooner than the other
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
TitanMike is offline   Reply With Quote
