04-16-2020, 09:10 PM
Depends on what grill ur using. Gotta figure out what size connector is on it because there are a few different options out there. They're not all universal. Check out my gas line install in here... Somewhere.... Lol
Originally Posted by Fishes
04-17-2020, 07:24 AM
don't really know what you are looking for. try www.propanegear.com. they have lots of stuff
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
04-18-2020, 12:24 AM
Might even find a propane place that sells and will build exactly what you need. Drag the trailer up, fill up your propane tanks and bring your grill and outdoor stove or anything else you want and they can make up quick connect hoses with whatever fittings you need for your appliances.
2020 Chevrolet 2500 LTZ, 2019 Forest River Wolfpack 23Pack15, 2014 EZGO Golf Cart.
04-18-2020, 01:44 PM
Originally Posted by CHICKDOE
X2 on Propane Gear. They had the perfect connector for my Blackstone and had the best price at the time I bought it.
I suspect the connector you need will depend on what grill you are hooking up.
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
04-18-2020, 01:52 PM
try this
I have a 2017 forestriver I used this amazon (REGNHLIF 2 Pack Propane Quick Connect Fitting-Full Flow Male Plug with 1/4 Inch Female NPT Thread) and a extinction hose ( DOZYANT 24 feet Low Pressure Propane Quick-Connect Hose, RV Quick Connect Propane Hose, Quick Disconnect Propane Hose Extension - 1/4" Safety Shutoff)
and i use this (DOZYANT 3.5 Feet Propane Regulator and Hose Universal Grill Regulator Replacement Parts, QCC1 Hose and Regulator for Most LP Gas Grill, Heater and Fire Pit Table) to connect a extra propane tank up.
04-18-2020, 01:57 PM
2019 Cedar Creek Silverback 37MBH
TV: 2017 Ford F350 CC DRW King Ranch
04-26-2020, 12:01 PM
Picking the Right Option
In this time today, I would like to suggest to just go with the Amazon options. It simple, they deliver, you try it and either keep it or return it. No going out down the road, incurring more risks than necessary. Just my 2 cents tho. Enjoy the camping times
04-26-2020, 12:09 PM
Every BBQ grill's connection is different.
Most, you have to remove the regulator to use the low pressure quick connect on the R/V but some grills are made specifically for low pressure.
Tell us what grill you have and we can likely make better than generic recommendations.
The are many many prior threads on modifying a grill to use on the low pressure port.
05-06-2020, 11:05 AM
Thanks! I have the "camp chef PG100" BBQ.
I think it would need unregulated pressure, either that, or a different valve on it.
05-06-2020, 12:02 PM
have you tried this hose GasSaf 5FT Propane Adapter and Hose Assembly Replacement with Hose for Type1 LP Tank and Gas Grill-CSA Certified (amazon)
05-06-2020, 12:04 PM
I'm not sure that would work. It doesn't look like it has to quick connect plug at the end.
05-11-2020, 09:33 AM
Originally Posted by jd4010
Looks like we may have different ends. I ordered the hose and it's too small to fit in.
