Old 10-25-2020, 11:54 AM   #1
LynnATX's Avatar
Fresh water tank drain
Is there a drain to empty the fresh water tank other than the low point drain on a 35thss? I've looked under the trailer and don't see one but I feel like there has got to be one because the low water point drain is only one white drain (not one for cold and hot) and drains extremely slowly.
2019 35' Puma Unleashed
2000 Ford F-350 7.3
Blue Ox Super Hitch
Best damn dog ever
Lover of dispersed camping
LynnATX is offline   Reply With Quote
Old 10-25-2020, 02:55 PM   #2
Iwannacamp's Avatar
I am making a couple of guesses..
1st it is a 351thss
2nd is the year of 19 or 20 year
The fresh tank drain would be curb side and in front of the rear axle. The video I saw was in front of the front axle and is a white 1 1/2Ē pipe sticking down with a valve. You must pull the handle to drain. Beware water will rush out assuming there is any volume there.
If not? Google your rear and model for walk through videos. They nearly always show that stuff
2017 Puma 297RLSS
Old 10-25-2020, 07:43 PM   #3
LynnATX's Avatar
Thanks you're right about the model. I found that but thought there might be another too. Don't most of them have a hot and cold drain?
2000 Ford F-350 7.3
Blue Ox Super Hitch
Best damn dog ever
Old 10-26-2020, 09:20 PM   #4
Iwannacamp's Avatar
Hot and cold low point(line set) drain. The fresh water tank is just the tank.
2017 Puma 297RLSS
Old 10-26-2020, 09:24 PM   #5
Iwannacamp's Avatar
There is a ton of draining here on the forum. Here is one worth the read. No 14 is good info.... i didnít read the whole thing.
Question - winterizing
https://www.forestriverforums.com/fo...d.php?t=218451
2017 Puma 297RLSS
drain, fresh water, tank, water, water tank
