Old 05-06-2020, 11:06 AM   #1
Radio White Noise
I can hear a white noise produced by the inside speakers whenever the radio is on.
Even when I have the radio set to only play on the outside speaker the inside speakers still produce a humm.
Any idea where I should start the troubleshooting?
Fishes is offline   Reply With Quote
Old 05-12-2020, 09:00 AM   #2
Prob a loose wire, start with the back of the radio, then speakers.
wtildens is offline   Reply With Quote
Old 05-12-2020, 09:04 AM   #3
Thanks. I'll give it a shot.
Old 05-12-2020, 09:11 AM   #4
Flybob's Avatar
If you are pulling the radio to check the wires, I suggest you might be prepared to redo all the speaker connections. When I pulled mine, the connections were poorly installed wire nuts. I removed them and replaced them with soldered /heat shrink sealed connections.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 05-12-2020, 10:34 AM   #5
KSH
I called coachman as my radio did the same thing. It was a drive 100 I think. They knew about the problem and sent a new one.
KSH is offline   Reply With Quote
noise, radio
