Old 04-01-2021, 01:42 PM   #21
Always Learning
Originally Posted by WanderMore View Post
You would probably do better to just buy a pancake compressor for at home and sell the Viair for more than the pancake compressor.
That's a thought, but I do want to keep the Viair for the RV.
ependydad is online now   Reply With Quote
Old 04-01-2021, 01:58 PM   #22
Trailer Park Supervisor
NJKris's Avatar
Can't blame you. It's nice to know you have it on road, even though I've only used it once at the beach topping off tires. And helped out a neighbor at the same park with it. I got it because of all the guys on this site saying how great it is! The Cadillac of portable compressors.
Yes, I drink the water!
NJKris is offline   Reply With Quote
Old 04-01-2021, 06:22 PM   #23
Keep the Viair. You'll always have 12V when traveling; you won't always have 110V.
Are you in a stationary location now with garage storage? If so, I concur with the suggestion of an inexpensive tank compressor if the battery clamps are aggravating. I'm in a house but don't use the compressor often enough that it bothers me to hook it up to the truck.
Alternatively, mount a Anderson connector on the outside of your vehicle and make an extension cord out of #10 wire? You'll have to consider the voltage drop when deciding the length.
That requires a matching connector on the pump. Cut the wire and add a pair of Andersen connectors on it. That way you can swap the battery clamps with the extension cord. Leave the stub on the pump long enough to plug that directly into the one on the truck without the extension cord.
TV: 2016 Ford F-150 RWD Lariat Crew w/ 3.5L EB, MaxTow and tow mirrors.
chriscowles is offline   Reply With Quote
Old 04-03-2021, 06:59 PM   #24
They recommend that you keep your engine running while using the ViAir. If you don't, you will lower the battery voltage which makes the compressor overheat. I burned up a couple of cheap compressors before I learned that lesson. The battery in my Jump Starter/Compressor is only a 20 amp-hour battery. Works great for jumping most vehicles, and you can charge your phone and run an LED work light if needed. My ViAir compressor will fill my truck tires faster than I can let air out. I let air out on rough roads to smooth the ride.
mnoland30 is offline   Reply With Quote
Old 04-04-2021, 02:10 AM   #25
I’ve got a Viair 12v compressor that I bought while fulltime. Lately to use them at home, I’ve been plugging into the truck and dragging air hoses around. It’s annoying.
Any idea how I can power this at home? Just a simple battery charger?
I understand your frustration. I ended up buying a $50 1/3 hp compressor from Harbor Freight and a 25ft coil hose. It handled my air nailer and 1/2 in impact. It doesn't weight much and the hose doesn't get all tangled up. If needed it will run off my 1500 watt inverter in my barn if needed.
2020 F-250 XLT
2020 Salem Cruise Lite 241QBXL
KE8SDQ
Ryan-OH is offline   Reply With Quote
Old 04-04-2021, 06:55 AM   #26
I went from no compressor to 26 gallon 100ft hose, found a small pancake compressor with short hose for $20 at garage sale. Got a battery jumper it has an air pump on it, however my go to for filling up rafts, tubes, 1 or 2 tires. I reach for my Ryobi air pump on tires I set the psi and walk away. Does great battery last for awhile plus I have 6 or so extra batteries from my other Ryobi tools
2019 F 250 6.2
2022 Columbus 329 DVC
moose074 is offline   Reply With Quote
Old 04-04-2021, 08:33 AM   #27
HONDAMAN174's Avatar
I’ve been using my viair with a battery pack for a while now- mine has the alligator clips so I just keep them separate and turn it on. I’ve gotten more use out of the battery pack by helping the occasional camper whose kids leave the lights on in the minivan. Jumped 3 cars and one rv over a cold weekend.
NOCO Boost HD GB70 2000 Amp 12-Volt UltraSafe Lithium Jump Starter Box, Car Battery Booster Pack, Portable Power Bank Charger, and Jumper Cables For 8-Liter Gasoline and 6-Liter Diesel Engines https://www.amazon.com/dp/B016UG6PWE...DDC2VD8P2KWWJ6
This holds its charge well and is usually half price on Prime Day
Just glad to get away
Old 04-04-2021, 09:22 AM   #28
Originally Posted by mnoland30 View Post
They recommend that you keep your engine running while using the ViAir. If you don't, you will lower the battery voltage which makes the compressor overheat. …
I hadn't considered the issue of low voltage = higher current. I haven't always run the truck engine when I use the compressor. I will, now.
Old 04-05-2021, 03:30 PM   #29
Always Learning
Chris, same. I almost never am running the truck when I'm topping tires up. I didn't see the point of burning fuel and figured there was always enough juice in the batteries to start the truck the next time. But I'll rethink that!
Old 04-05-2021, 03:31 PM   #30
Always Learning
Thanks for the link and personal experience with it! I'll watch for a sale on these.
Old 04-05-2021, 03:44 PM   #31
I have an even larger one of those, said it will crank a 10 liter diesel. It would NOT crank my Caterpillar C9. Not even close. Cars yes, but they far over-estimate the cranking power when you really try to use it somewhere near the limit they advertise. And, it was a warm spring day. Hooked up jumper cables from my truck and it cranked right up.
Rockwood Ultra Light 2304DS, towed by 2018 Ram Cummins Diesel 2500 4x4
RobbieH is offline   Reply With Quote
Old 04-05-2021, 03:50 PM   #32
Always Learning
Fortunately I'm not actually expecting it to crank my diesel.
