Originally Posted by Unclesam
2016 Forest River FR3 -
1. Have water heater button inside rv on control panel and also a button outside on the water heater.. So the question is.. The button out side do you turn that one on if dry camping to use propane or the inside the rv button?
2. Turn the water pump button on inside the rv..Is it suppose to make noise all the time or just when you turn some water on in a sink or flush toilet?
Thanks very much for input...
Please tell us the make/model of YOUR water heater.
Not all R/Vs have the same model or even the same brand.
boodocking's post was spot on for the most common, but not all, especially if it is a tankless model. And don't forget, to operate the water heater on propane, you must have propane in your tank(s) and the valve has to be open. You wouldn't be the first...
Once pressurized, the pump should only continue to run if you open a faucet or flush the toilet. Leave the pump switch on the entire time you are camping. It will cycle as necessary.
