Old 10-10-2010, 07:04 PM   #1
EastlakeRoo's Avatar
Question 2010 ultralite 2607 low point drains
Does anyone know if this trailer has low point drains?
2014 Wildwood 300BH
2014 Ford Explorer XLT
2011 Ford F350 FX4
Eastlake, OH
EastlakeRoo is offline   Reply With Quote
Old 10-11-2010, 03:09 AM   #2
I took a look under the trailer and found the low point drain for fresh water but didn't know if there were ones for the hot/cold.
2014 Wildwood 300BH
2011 Ford F350 FX4
Eastlake, OH
Old 10-11-2010, 02:18 PM   #3
Grape Escape
Our 2006 2607 had some drain valves under the couch Be sure to check for the black in line valves
2008 Cardinal 30RKLE 5th wheel sold
2006 Rockwood 2607, 2001 Traillite
55 nights 2009, 53 for 2010
44 for 2011, 38 for 2012, 35 for 2013, 51 for 2014
dezolen is offline   Reply With Quote
Old 10-11-2010, 02:44 PM   #4
My ultra light has them just in front of the rear bumper on the door side. red and blue with a cap screwed on.
bill and theresa is offline   Reply With Quote
Old 10-12-2010, 09:24 AM   #5
My Flagstaff 26RBSS,same as 2607, has drains under the sofa in the slideout plus the one on the freshwater and the water heater.
15 Flagstaff 26RLWS
08 Silverado 1500 Crew
dlc49 is offline   Reply With Quote
Old 10-12-2010, 11:09 AM   #6
Is it easy to catch the water for the drains under the sofa? Just don't want a mess with water flowing everywhere.
2014 Wildwood 300BH
2011 Ford F350 FX4
Eastlake, OH
Old 10-12-2010, 12:47 PM   #7
Nights Camped in 2010 - 2
Anyone know where the low point drains are on a 2604? I have an enclosed underbelly and would like to avoid removing panels or at least limit the number I need to pull. Thanks,
George Kelly
2011 Rockwood Ultra Light 2604
Dodge RAM 1500 Larime 4x4, 5.7 HEMI
Nights Camped 2010 = 18
Nights Camped 2011 = 15
sailingsuppo46 is offline   Reply With Quote
Old 10-12-2010, 03:34 PM   #8
Grape Escape
Drains under slideout couch should go thru floor to outside. Your trailer does not have enclosed underbelly does it?. At least in 2006 it was not
Old 10-12-2010, 03:53 PM   #9
Yes mine is enclosed also.
Old 10-12-2010, 04:47 PM   #10
realebill's Avatar
i have a rockwood 8315SS with an enclosed underbelly. the lowpoint drains are easily accessable right next to the rear steps. blue and red capped fittings.
realebill is offline   Reply With Quote
Old 10-12-2010, 05:04 PM   #11
My underbelly is enclosed as well. I'll crawl under the trailer and see if I can locate the drains.
2014 Wildwood 300BH
2011 Ford F350 FX4
Eastlake, OH
Old 10-13-2010, 06:42 AM   #12
Mine is enclosed. I will crawl under there tonight and take a look in the areas discussed here. I did see an access panel mid way on the slide. Been looking for an excuse to pull a few panel screws anyway. Thanks everyone.
George Kelly
Old 10-19-2010, 04:02 PM   #13
Fire Instructor's Avatar
Did you find it? My 2607 has two pull valves under the sofa, draining to the outside. The tricky thing on MY 2607 was the water heater. If I drain the WH, the close the bypass, there is still water trapped in the lower pipe between the WH and the bypass valve. The first year I had this unit, this pipe froze, and failed right at the valve. So now I drain, blow-out, then close the bypass, then pump the pink stuff through the system...
Fire Instructor
2014 RAM 2500 Laramie 4x4 Quad Cab w/Cummins Turbo Diesel, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
Old 10-19-2010, 04:21 PM   #14
Thanks for the order to winterize as this will be my first time doing this trailer.
2014 Wildwood 300BH
2011 Ford F350 FX4
Eastlake, OH
ultralite
