11-24-2017, 11:56 PM
#41
Originally Posted by DeeWayne
Could be- My wife sez I'm not always right..
You are correct- I was thinking of weights and got my percentages in the wrong place-- the pin hitch can =handle more weight that the tounge hitch==like 20-25% while the tongue hitch should be around 15%.
11-24-2017, 11:58 PM
#42
Every fiver we have had has 15%-17% pin weight. Guess we are lucky
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
11-25-2017, 12:01 AM
#43
Originally Posted by itat
DeeWayne, your figures are backwards. The pin weight of a 5er should be 20-25% of the trailer’s weight. The tongue weight on a TT should be 10-15% of the trailer’s weight.
you are correct
11-25-2017, 12:42 AM
#44
Insert witty title here
From everything I've read, that sounds low. Perhaps you need load more of your trailer cargo forward of the axles.
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
11-25-2017, 12:52 AM
#45
Why? When they all pulled perfectly? Oh...dang, you got me with another bait comment
11-25-2017, 01:11 AM
#46
Happy camping.
11-25-2017, 07:44 AM
#47
Actually, I agree with you, dry pin weights are frequently under 20%, but because fivers have so much forward storage, it isn't unusual for the loaded pin weight to exceed 20% of the fully loaded weight. So, really everyone is right.
Larry Day, Texas Baptist Men volunteer since '01
'13 Silverado LT 3500HD D/A CCSB 2wd, custom RKI bed
'17 Puma 351THSS toyhauler
11-25-2017, 08:15 AM
#48
Throw a front bath in there or a washer dryer and the pin weight can be 25% easily every more with junk in the front storage bay.
11-30-2017, 10:39 PM
#49
My scenario
OK since this post was at an end I would like some input on my configuration. I don't know if this is considered highjacking a post or not so sorry if I did. I have read these posts on pin weight and cargo capacity etc for many months now after I joined the forums. I have researched and read and read and read and of course you get so many different answers you think you are going crazy. Anyway I have a 2017 CC 34RL2 empty weight of 12K and GVWR of 16K. I tow with a 2017 Ford 250 SD 4WD CC SRW diesel with airlift airbags. So far all feels really pretty good. I keep reading about DRW's and F350's and wonder if I'm within limits. I weighed rig etc and still am not sure how to calculate pin wt etc. My payload (on the doorpost) is around 2100 so I'm just not sure. Any ideas would be welcome. I just want to be safe but also understand that everyone has an opinion. Drove a DRW today just for kicks and yes it is indeed stable. But also this RV ing can break a guy.
11-30-2017, 11:34 PM
#50
I'd have to agree with the other post about driving your setup around for a while then deciding if you feel "overweight". Most TV's pulling a fiver are technically overweight, but unless you are over the capability of the axle weight and/or tires or drive like an idiot then you aren't a danger to society. Some people act like fivers are laying on their sides on interstates all over America. I can't help but to think that some people are jealous of others that do more with less.
At first I was a little apprehensive about towing our fiver with our F250 (2250# door sticker, 2100# dry hitch), but once I drove it around the first time the truck felt more than capable and I didn't believe I would endanger my family or yours. After 10 trips, my opinion hasn't changed. Indeed these trucks are built for much more than that little yellow stickers says.
Have fun y'all
2018 Coachmen Chaparral 360IBL
2008 Ford F250, V10, 4.30
11-30-2017, 11:41 PM
#51
Your Ford is a towing beast. That being said be aware how much weight is on your rear axel and tires. With the air bags your axels and tires should hold 6K# with no sag. With a 5er that size you are in F350 SRW and maybe duly territory.
Joe & Beverly
2014 Ram 2500 CTD, CC, SB
2014 8289WS lifted
11-30-2017, 11:42 PM
#52
Back to the original question. This might be blasphemy on a Forest River forum, but DW and I saw an Open Range Light 318RLS that we fell in love with. It’s similar to our 2703WS floorplan but the living area felt much brighter and more open. They are 100” wide. About 10K GVWR and just over 8K dry. Pin weight around 1200 to 1400#. These are advertised as “half-ton towable”.
2017 Rockwood 2703WS - Sold
2015 Keystone Sprinter 333FWFLS
2017 F250, 6.2 Gas, 3.73 Axle, 2902 lb Payload
If women don't find you handsome, at least they should find you handy!
12-01-2017, 07:24 AM
#53
Short answer is you are exceeding the truck's payload. The 34RL2 has a DRY pin weight of 2270 lbs, your payload is only 2100 lbs which is reduced by options, weight of hitch, passengers, misc. So, even with an empty trailer you are in trouble with just 2100 lbs of payload. But your truck's payload is artificially limited by it's GVWR rating minus it's dry weight.
The real critical answer is are you exceeding the rear axle GAWR and tire capacity of the truck? You need to take your fully loaded truck and trailer to a weight scale and get individual axle weights, specifically the truck's rear axle weight. Then compare that number to the axle GAWR and the tire capacity. Are the truck tires rated at 3042 lbs each or do they have a higher rating, closer to 3500 lbs? You really need the weight info.
