Any advantage to 50 amp?
Yes! Yes! 1000 times YES!
Even if you never go with the second air, you won't have to worry about blowing the breaker if you are using the microwave and the coffeepot at the same time the air is running, or other such situations. A simple $25 adapter will let you use it on a 30A if you ever have to, but 50A is getting more and more common. I have yet to plug mine into 30A, except at my house.
The big advantage is, one day you may decide to bite the bullet and go with the second air. At that point, you will be kicking yourself if you didnt do the 50A upgrade.
It's worth EVERY penny!
tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
"Camper" 2016 Rockwood Signature Ultralite 8329ss
"Casper" 2017 Ram 2500 Laramie Diesel
..ProPride 3P Hitch - "Yeah. It's worth it."
