Old 04-11-2017, 01:48 PM   #1
5er Wobble
Newbie here. Just got and set up my 5er and used auto level. It is level but has a wobble to it especially in the rear. I have the 6 jack auto level. The jacks are extended pretty far out on the rear. I think if I pull up the rear jacks and add some leveling blocks so the jack is not extended so far and relevel that that will take care of it. Am I barking up the wrong tree? Also if the tires are off the ground on one side by about an inch do I need to put blocks under it? The Curse of the newbie.
Thanks in advance!
gamtnbear is offline   Reply With Quote
Old 04-11-2017, 01:54 PM   #2
wobble
I also have the auto level. What I do to reduce wobble is try to keep all 4 wheels on the ground. I do this by making sure the from jacks are partially extended before I pull the pin and drop the front legs. I also use some wood blocks to level up the trailer from side to side before auto leveling. Still get some wobble but it helps.
I haven't tried the locking scissor jacks between the wheels. Would like to hear if others have found this is helpful or not.
___________________________
2016 GMC Sierra 6.2L gas
half ton with towMAX package
2016 Crusader 295RST (5th wheel)
Camped 80 days in 2016, 42 in 2017, 42 so far in 2018
Ontario Sam is offline   Reply With Quote
Old 04-11-2017, 06:22 PM   #3
5er Wobble
1st, all tires should always be on the ground. I use 2x6's for this. I try to get as close to level side to side using these before auto level. Next the longer the legs are extended the more wobble you will have. I use 6x6 blocks to reduce that distance then I auto level. I also have the Steadyfast system that is kind of like JT Strong Arms that also helps. And since mine is 42' I also use a tri pod under my kingpin for long stays.
Dinostop is offline   Reply With Quote
5er
