Old 02-08-2022, 10:36 AM   #1
A/C Condensate/Water running under the Roof ?
We noticed some dried water streaking on the inside bedroom wall across from the bedroom air conditioner. There does not appear to be any leakage from atop/side of the roof. Wondering IF there is a way for the condensate/rain water to penetrate through the A/C unit down under the roof and run over to the inside wall? When the A/C is running it appears that the condensate is flowing smoothly across the top of the roof and dripping normally out of the gutter corner.
Sierra Destination Camper - 2017 401 FLX
dcavaiani is offline   Reply With Quote
Old 02-11-2022, 11:23 AM   #2
Take your ac cover off and check out what is going on
loyda is offline   Reply With Quote
Old 02-12-2022, 07:27 AM   #3
SeaDog's Avatar
It might be that the gasket around your AC is allowing some condensate to leak inside make sure the AC is tight to the roof and also remove the cover and insure all the drain holes are clear from the coils to the pan. let the forum know what you find
Retired Navy
2016 Flagstaff 26 FKWS
Old 02-12-2022, 08:05 AM   #4
Will do! Just that it is going to be a couple of months before (it's parked at campground which is closed) I will be able to check it out.
Old 05-07-2022, 10:20 AM   #5
I wish I knew more. I really cannot see where the drain holes are ??Click image for larger version
roo, roof, water
