A/c easy start
Just did a Easy Start on my friends secondary a/c system. he's on his way next week to Nascar Races and he'll be boone docking it in a field. He is running two small generators in parallel which he said has the ability to run them with the a/c's on but start up puts a big load on them. So last night we did the install I used weather cinnectors and and shrink wrap making it a clean water tight connections. We were running the coach off a 20 amp service and the lights didn't dim one bit when the a/c cycled on. Actually you have to cycle the a/c system like 5-6 times for the littlle magic box understands the load the a/c unit uses.
So not a real bad Idea because I remeber when I had the notor home the load the 2nd a/c system would put on the generator.
