Originally Posted by ArkRVHog
So from going from the hot south to the cooler north, I've had to add about 5#'s of pressure in my Class C tires to get them up to specs. It has continued to cool a bit so checking my TPMS, I'm down about another 3-4#'s but once I'm on the road for 30-45 minutes...all tires are above inflation specs as normal.
Yes, tire pressures decrease when the weather gets cooler. You should be adding air when tires are below the correct pressure as measured in the morning. Under-inflated tires will heat up more than fully inflated tires when rolling, making rolling measurements a crap shoot. Every year, in Colorado, a cool fall night will result in a bunch of TPMS warnings the next day, and the tire shops will be full. My first check was to see if all 4 tires were reading slightly low. If yes, I needed to add cold winter air to the tires. If one tire was low, I had a tire problem.
Tire pressure also decreases when you go to significantly lower altitudes.
When I lived in Colorado, I would adjust my starting cold tire pressures a couple of PSI higher if I were going to a lower altitude, and add a couple of PSI more if the predicted weather was going to be cooler. That way, I would not be under-inflated in any likely conditions. I also have about a 10PSI margin according to the tire weight capacity charts by using the camper placard/tire sidewall pressure (same on my camper).
I am running OE Castle Rocks on their 4th year on my camper with no issues. I think a part of that is from not overloading or under-inflating.
Fred W
2019 Flagstaff T21TBHW A-frame
2022 Hyundai Palisade
