Old 06-13-2020, 11:43 PM   #1
Analog vs. Digital Coleman Thermostat
Read a lot of people who switched from the analog to Coleman digital thermostat. It's a basic 1 to 1 switch. But I am curious, for the people that have changed to the Coleman Digital, is there really much difference in the way the AC runs? Does it run more consistent or keep the temp better? Is it worth the $65?
If anyone installed a different thermostat that they really liked, I'd love to hear that too. I know when going with another brand, you lose the Low/High speeds, but I don't notice a difference in those now.
Thanks everyone.
DadJones is offline   Reply With Quote
Old 06-14-2020, 12:19 AM   #2
dbledan's Avatar
Yes! Very different with the digital version. I just swapped to the digital coleman. I believe the analog had a 4 degree swing. The digital is a 2 degree swing. Much better in terms of performance.
dbledan is offline   Reply With Quote
Old 06-14-2020, 12:41 AM   #3
That's great to hear.
Old 06-14-2020, 01:39 AM   #4
DavidBo's Avatar
Very worth it, and I also see little difference in fan speeds.
DavidBo is offline   Reply With Quote
Old 06-14-2020, 05:24 AM   #5
We switched our thermostat. First change we made to our 2017 Microlite. The temperatures in the trailer would swing from smoking hot to freezing cold. Furnace was kicking on and off too much. The digital thermostat controls the swings in temperature much better.
DanMistyMiler is offline   Reply With Quote
Old 06-14-2020, 12:19 PM   #6
jbrosecity's Avatar
Last year I replaced the two analog thermostats that came with my 2019 fifth wheel. My aging eyes had a hard time seeing the tiny print on the temperature slider. The digital unit has up down arrows which change the setting one degree at a time. So it is just easier for me to use. The analog ones worked fine and are brand new and if anyone wants them, send me a private msg with any reasonable offer and I'll send them to you.
2019 Forest River Forester 3041DSF
Ford E-450 Chassis
www.Wind-seeker.com
2018 Vanleigh Vilano 375FL
www.Wind-seeker.com/vilano
jbrosecity is offline   Reply With Quote
Old 06-14-2020, 12:40 PM   #7
st4
from south Louisiana
Microaire just came out with these
2020 Rockwood Mini Lite 2109S
2018 F150 3.5 EcoBoost
st4 is offline   Reply With Quote
Old 06-14-2020, 01:04 PM   #8
SailorSam20500's Avatar
I also did the switch a couple of years ago. Analog t-stat had temp swings large enough that the DW was constantly adjusting the temps I was always too warm or too cold. Digital keeps things comfortable.
Swap was an easy 1 for 1 wire replacement - wire colors were almost perfect but easy to figure out. While I was at it, I glued some heavier wood on the back side of the wall panel to improve the screw grip holding the t-stat.
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
SailorSam20500 is offline   Reply With Quote
Old 06-14-2020, 01:17 PM   #9
Thanks everyone....
Old 06-14-2020, 01:53 PM   #10
What is the digital t-stat part number?
Thanks in advance
Johnv656 is offline   Reply With Quote
Old 06-14-2020, 03:00 PM   #11
I made the switch but didn't see as much improvement as I hoped. It is easier to see the temp setting with the digital vs the analog slider. I expected the digital to be illuminated to read at night but it is not. I can't really tell a lot of difference in the cycling but that may be because I was never really sure of the settings with the slider.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
CedarCreekWoody is online now   Reply With Quote
Old 06-14-2020, 03:39 PM   #12
Can you run 3800 fps?
I changed it out at the beginning of the season. Had one trip with it, and an 88 degree and a 92 degree day. The Digital ran less often that the analog would have and still kept the inside of the trailer at a cool 72 degrees on both days. Best upgrade since the 320 toilet with the quiet closing seat!
SniperDroid is offline   Reply With Quote
Old 06-14-2020, 03:43 PM   #13
DavidBo's Avatar
I got this to replace my stock Coleman-Mach analog thermostat:
https://airxcel.partsvia.com/product...--CLM9430-3382
Super easy to install, basically just snip the wires and follow the color code on the little terminal strip. I also like how the display illuminates when a button is pushed. It's far more accurate, keeps the temp within a couple of degrees.
The only issue is the size, it's quite smaller than the original unit and barely covers the hole Forest River hacked into the wall. It also leaves the old mounting holes exposed, I patched those with little bits of wallpaper harvested from inside a storage bay.
The website has a variety of thermostats with cross references to older parts, and I believe Airxcel is the parent company of Coleman-Mach (or vise-versa) so their parts should match up easily.
Old 06-14-2020, 03:46 PM   #14
Utah Traveler's Avatar
Much more accurate than the old analog. only2degree swing, keeps up with a constant temp. much better.
2016 Rockwood 2109S
2014 RAM 3500 - Cummins
165 Watts of Rooftop Solar
Utah Traveler is offline   Reply With Quote
Old 06-14-2020, 06:03 PM   #15
Thanks in advance
Check out Amazon - Coleman 83303862 Digital Thermostat
https://www.amazon.com/s?k=coleman+r...b_sb_ss_i_2_29
Plenty of choices
KEN9XL is offline   Reply With Quote
Old 06-14-2020, 09:29 PM   #16
So does it have to be an RV thermostat or can you buy a nice blue tooth controlled thermostat?
RJKerr83301 is offline   Reply With Quote
Old 06-14-2020, 10:41 PM   #17
dbledan's Avatar
My other advice is to stuff some insulation into the wall when you remove the thermostat. It will also help to keep the swings and cycling.
Old 06-14-2020, 11:56 PM   #18
DavidBo's Avatar
It is possible for some residential thermostats to be used, but usually not without modification. There are a few YT videos on how to do it, the main advantage is that those tend to be cheaper than RV specific units.
There are dedicated bluetooth thermostats available for RVs, I have a WiFi one for my house and I'll certainly admit it is handy.
https://www.airxcel.com/rv/coleman-m...th-thermostats
Old 06-15-2020, 05:56 AM   #19
st4
The new rv thermostat from microaire is WiFi operated too
Old 06-20-2020, 03:06 PM   #20
Thank you for the ordering info link.
Plenty of choices
Ordered and just installed the
Coleman 83303862 Digital Thermostat .
Took less than 5 minutes to swap out wire for wire. I was on the fence on whether to replace the slider thermostat and this thread convinced me to do it with the correct part. We are always looking to improve things on our 2019 MicroLite 21DS (aren't we all). Looks like it will improve the temperature swings. Thank you.
Pred is offline   Reply With Quote
coleman, thermostat
