Old 05-23-2020, 02:33 PM   #1
Ants Ants
I am having an issue with ants on and in my trailer
Any ideas on how people are controlling this issue would be great
Rwbaker65 is offline   Reply With Quote
Old 05-23-2020, 02:55 PM   #2
What kind of ants? Big ants or small sugar or ghost ants?
I’ve had good luck with this. Follow the ants to see where they enter and leave a squeeze a small amount in their path. They will take back to the nest..
You can get this in most stores. I get it in Lowes.
https://www.terro.com/terro-liquid-a...RoCbxoQAvD_BwE
2016 Siverback 33IK, Towed 30K+ miles
Andersen Ultimate Hitch
RadMini Stepthru eBikes
Old 05-23-2020, 03:25 PM   #3
Hclarkx's Avatar
I read that sprinkling a bit of cinnamon in a ring around the wheels and jacks will create a barrier that ants will not cross. I tried it and it worked. I watched the ants try to find a way around it. Though the ants were already inside so I had to resort to ant traps for a while.
I've also gotten ants from parking in contact with a bush. Cinnamon does not work there. The solution is to avoid any such contact with the RV. This includes grass or weeds under the RV.
2020 GMC Denali 2500HD Crew 4X4 Gas 6.6L
2015 8280WS Rockwood raised 3"
600W solar 300AH LFP battery 900W PSW inverter
Hclarkx is offline   Reply With Quote
Old 05-23-2020, 03:37 PM   #4
As mentioned above, the Terro works well on sugar ants.
Fire ants will ignore it, and Amdro will work if you're parked where you can find the mounds and it's permitted.
For any kind of ants, diatomaceous earth will work on any bug that crawls over it. Unfortunately, it doesn't like getting wet, so you may have to reapply.
We've used Lysol to kill them inside the trailer.
You need to put all the food you can in plastic to minimize the smell of food an keep them out of cupboards.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 05-23-2020, 06:06 PM   #5
Thanks for all the replies
I’m trying some terro which my girlfriend suggested ��
Let’s hope it works cause I hate ants ��
I really don’t see any in the cupboards luckily
Old 05-23-2020, 10:04 PM   #6
Boss Ox & Drovergirl
oxcamper's Avatar
Boric acid dissolved in water to make a paste and add some sugar, then take it back to the nest and die.
This is what most professional ant remedies are based on.
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2011 2500HD Silverado
1992 Goldwing Aspencade
oxcamper is offline   Reply With Quote
Old 05-23-2020, 10:16 PM   #7
FLY4FUN
Terro + patience. It works.
14apex is offline   Reply With Quote
