09-25-2020, 09:16 AM
Anyone ever seen this?
Have a question, has anyone every seen these types of bumps under wall covering?
Thinking some type of growth, but they are very hard. I have no water damage on my rig, and maintain meticulously
09-25-2020, 04:24 PM
I have those on the back wall of my camper. Was told it was because of moisture. They were there when I bought it and they have not gotten worse. I freaked out about it when I found it.. the previous owner had tacked up a poster there so I didn't see the damage at walkthrough.
I don't trust anyone now.. learned my lesson with that one.
09-25-2020, 05:01 PM
I wonder if those bumps were the result of powder post beetles?
https://en.wikipedia.org/wiki/Powderpost_beetle
Those bugs leave eggs in the wood walls ( from infected lumber used by the builders), and at some point hatch out, usually leaving a little sawdust behind and a tiny hole in the wood.
FYI... powder post beetles exist in the oak beams of bourbon rick houses in KY... I always wondered what all of the saw dust (powder) on the floors of the rick houses were when I would go on bourbon tours. Of course the thousands of barrels are stored on strong oak shelves and are stacked many floors high. The answer to my question was always "powder post beetles and they don't hurt anything"... that is until 2 years ago when one of the Barton Bourbon warehouses fell down in 2018. In September of 2018 I was visiting the Bardstown area and happened to meet a worker from a local company that had salvaged some of the oak lumber of the fallen warehouse. He confirmed to me that many timbers were too infested and damaged with those beetles to be considered to be recycled. It was an interesting discussion I had with him and was able to share an adult beverage with him.
2014 Shamrock 183
09-25-2020, 06:57 PM
That is a sign of water intrusion, sorry to say. You have a leak somewhere.
2020 S.O.B.
2016 Jeep Wrangler 75th and a
Cooler full of good ideas
Full Time in the Summer, soon
Part Time in the Winter
Days Camped, Not Enough
09-26-2020, 02:56 PM
What model and year do you have for an RV? Is it still under ?
But in the meantime I've heard, like others suggested, that it is water penetration or moisture. Is this area near a window, above basement storage or door way? If so outside where those points are check the caulking or rubber gaskets for access points were it can enter in. When i had a TT every spring I'd check everything on the outside, remove and re-caulk areas that looked suspect. So much flex with these homes on wheels its not a surprise but even with all that one warm spring day opened it up to find under one window water damage. Also I read someplace that the adhesive they use to adhere the wallpaper to the walls has water in it sometimes and if its near a sunny, warm side its the water coming out of the adhesive. Others can chime in but perhaps take a hairdryer on some low heat on the spots with maybe a flat plastic object carefully run it over it see if it re-seats back down? Another thought if these are hard, sharp bumps I'd go with glue since IMHO what intrusion wouldn't harden up and if its not near a window, etc. It would be strange to have water damage away from a means to enter. Thanks and let us know what you find out and you did to resolve it.
Dana & Terri - (Retired)
Our Cocker Spaniel "Shadow" (6 y/o)
Stephanie (daughter)/Rick/Callie (14 y/o)
Great Granddaughter - Cora (2 y/o)
Great Grandson - Zek (1 y/o)
Phillip (son)/Charlotte (6 y/o)
09-26-2020, 03:29 PM
About a year ago there were several posts with photos just like this that were found to have powder post beetle problems in the Luan.
Many had the wall/ceiling board replaced under warranty.
Days Camped ☼ '19=118 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=118☼ '24=64
09-26-2020, 03:52 PM
Member since 2018
I actually created this problem in the bathroom of my Isata 3 by doing two things wrong:
1) I wasn't running the exhaust fan enough during and after a shower. If you don't you can feel moisture on the wall, which creates the bubbles.
2) I installed a towel rack on the wall allowing towels to hold the moisture against the wall.
I fixed the problem by:
1) Removing the towel rack and went to one that hangs on the door.
2) Sanded best I could to remove the bubbles and smooth the wall best I could. (Only a minor spot that isn't perfect.) Then painted the wall with Kilz and again with a semi glows paint that closely matches the wall covering from factory. Turned out great and with running the fan enough, problem solved.
09-26-2020, 05:53 PM
Moisture issues
When not in use, I keep a dehumidifier running in my Lexington. Figure it can't hurt and most likely helps. I run the drain hose thru a hole in the battery compartment so I don't have to empty the dehumidifier bucket. You can get a pretty good unit on Amazon for a couple hundred bucks.
09-26-2020, 08:37 PM
I have the same bumps. Had the 5er since new 2014 but they just showed up this summer. I don't see any other damage(like water stains). I would hate to sand it off and have a bigger mess. If it is from powder post beetles I will have to figure out how to stop them.
2014 Signature Ultralite 8280ws
2013 Chevy 2500 Duramax
09-26-2020, 09:06 PM
X2, water intrusion. Find the problem above those bumps and fix it before it gets worse!
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
09-26-2020, 09:13 PM
I see no indication of water intrusion. Why would they be so hard ? Water is going to bubble up the paper and leave soft pockets not rock hard BB's under it.
09-26-2020, 10:18 PM
Member since 2018
The bumps actually get hard from moisture. They didn't remain soft in my case. Again, I sanded them down and painted. Mess was minimal. It was actually easy to fix. I also had the roof inspected and looked for any possible leaks on my 2 yr old motor home. The cause was definitely moisture from the shower. And it looked just like your photo.
09-26-2020, 10:39 PM
X2. Could be mould.
09-28-2020, 03:50 PM
100% it is water damage. Like it or not
09-28-2020, 04:26 PM
Location: Alberta - East of the Rockies, West of the Rest
If this is near a corner, window or door it is likely a sign of water damage, possibly caused by condensation due to the lack of ventilation. Running a dehumidifier during the high humidity season should prevent this from happening.
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
09-28-2020, 06:21 PM
Happy Keystone Owner
Looks like pine sap/pitch to me.
'15 F150 Ecoboost Maxtow Scab '19 Keystone Laredo 225MK
Days camped 2020-37 2019-36, 2018-24, 2017-46, 2016 -56, 2015-33,
2014-47,
Years camping....55
09-29-2020, 04:36 PM
Jertan19
I had the same thing it turned out to be water coming in around the window frame. I think you have a water problem.
10-01-2020, 07:12 PM
Water leak.
Same problem with my previous RV. Front marker lights did not have gasket installed at factory. Problem started not long after purchasing from original owner. The front wooden frame had dry rotted before paneling started to produce the bumps. I removed and rebuilt complete front, sealing everything. It fixed problem. Always be on the lookout for any place water can penetrate. Good luck.
10-01-2020, 08:14 PM
That is a water leak. We found those bumps on our rig just 1 week out of warranty. The bumps were located under our window of the slide-out. Like you, we take meticulous care of our rig. There was no visible place where the water could be coming in. The floor was dry. It was crazy.
Forest River was willing to replace the face wall free of charge, thankfully. Once they removed the original wall, they found that the window had not been property sealed during construction. We could not have prevented it nor could we have known it was defective. It leaked from day one.
We are deeply grateful for Forest River's willingness to help us through this deeply distressing event.
10-01-2020, 08:59 PM
I just had the same experience and these bumps are due to a water leak. In my case the window gasket was folded over and leaked water into the wall. Forest River replaced the wall. I had asked a dealer and they did not know what it was. The tech at Forest River told me that any bumps or protrusions on a wall are due to a leak. I actually had two windows that were leaking due to bad gaskets and three dealers completely missed this fact.
Steve
2023 Jayco 195RB
