If you are going to use the 5-6 gallon jugs, which we do from time to time, make sure you have an appropriate hose or other method, to introduce them to your fresh tank - if that is your intention.
A "Water Bandit" and a short section of (larger diameter) garden hose would also work.
Some RV's have the fresh fill nice and on the outside, others have it tucked in and you need a way to get from the jug to the fill opening. Some people might want a pump, as the jugs of course weigh 40-50 Lbs. when full.
A "Water Bandit" is also terribly handy to have in some other situations, this is a case of "To Have is better than To Want." It's a $4 - $6 item with a little diligent shopping.
We are curious about the Aquatank, while we are re-purposing the 22 gallon tank and pump removed from our previous TC, having a LOT more water capacity when we are at our boondocking location would be ... pretty much worth it's weight in gold.
Jeff and Abby
Fur Babies - Xandra Sophia (GSD) and Neo (Min-Pin Mutt who thinks he is a cat)
2015 Tracer Air 235 (previous 1994 Veri-Lite 1130 TC)
1998 Dodge Ram 2500 Quad Cab - 360 - 46RE (Built)
