Old 06-06-2017, 10:55 PM   #1
nodrawers's Avatar
Axles offset
I just replaced my manual adjust brakes with self adjusting brakes and at the same time I changed from 205/75R15C to 225/75R15E on my 2011 Coachman Catalina 22FB. Bigger tires. Of course I checked for clearance. Lots of room. Short trip and check showed rubbing in inside wheel well on passenger side. None on driver side, lots of clearance still. ????? turns out that apparently they placed the spring hangers and equalizer hangers too far apart. So instead of removing and correctly placing they just bent the hangers at an angle to the inside to get the springs to fit. of course this caused that side to have the tires closer to the inside fender well. Has anyone seen anything like that right out of the factory.
Tom & Laura USAF Ret Smsgt
1995 2500 5.9 Cummins 5 sp 3.54 diff
Days Camped 2016 91, 2017 110
Days camped 2018 136
nodrawers is offline   Reply With Quote
Old 06-12-2017, 09:38 PM   #2
SilhouettePenny's Avatar
Installed incorrectly or possibly damaged during transport? Can you post some pictures of the spring hangers and possibly take some measurements between hangers and equalizer so we can give a better perspective.
2017 F350 Dually 6.7
2019.5 Hathaway
He who dies with the most tools, wins!
SilhouettePenny is offline   Reply With Quote
Old 06-12-2017, 11:45 PM   #3
nodrawers's Avatar
Offset Axels
Here is pic of hangers front and rear. Couldn't get pic of center but it's the same. Couldn't have been done after axles installed or driver side would also be bent and those hangers are perfectly straight.
Will have to try and get some pictures in daylight. Flash didn't work. Sorry
Old 06-13-2017, 12:09 AM   #4
Just as confused as you
Scrapper's Avatar
Pics? They did not upload properly.
Richard & Jill
axle
