Originally Posted by Aaron2018
dbledan, where did you position the antennas? I found that mounting the monitor around my rearview mirror did not work. Don't know if it's too close to electronics or if the roof blocked too much of the signal.
Mine sits in the center of the dash in the indent on the f350. Antenna sticks up and I usually match with the angle from the camera. My camera is 90degress because it hits the furrion mount so I keep the monitor at the same angle.
I did turn off wifi on the truck. On my F150 my furrion camera was suctioned to the rear view mirror and antenna was 90 degrees along the roof line and never had an issue.
I do not have the amplifier for the camera.
