Old 10-30-2019, 07:43 AM   #1
Battery removal
First time wintering in southern FL. TT will be stored. Refrigerator runs on 12 volts..should we disconnect the battery
Jcyesiam is offline   Reply With Quote
Old 10-30-2019, 07:48 AM   #2
007matman's Avatar
You're going to find a 1000 different answers (mostly opinion) on this.
I'd say yes for long term storage. Couple of weeks up to a month? No.
What are you doing putting that thing away now? The seasons not over yet! You still got a couple of months left maybe a week or two after that till the next season starts!!
Revised.. ok. I shoulda looked at your profile. You're from NC so maybe you have a little more excuse.. I assume you're leaving the camper there.
007matman is offline   Reply With Quote
Old 10-30-2019, 08:21 AM   #3
Trailer Park Supervisor
NJKris's Avatar
Not sure what the fridge has to do with it. I never run fridge between trips, waste of power and more wear and tear on the fridge. But I would disconnect.
Yes, I drink the water!
NJKris is offline   Reply With Quote
Old 10-30-2019, 08:22 AM   #4
Are you planning to leave the refrigerator on? (not sure why you mentioned refrigerator runs on 12v)
We need more information as to exactly what you are planning to do before we can give advice.
There are many ways to store a R/V depending on circumstances/make/model.
Days Camped: '18=48 '19=58 '20=110 '21=116 '22=112 '23=83
Old 10-30-2019, 10:58 AM   #5
FR surveyor tt with residential frig ever chill.
Unable to charge battery in storage. Finished traveling for the next 4 to 5 months
Just came off of a 12000 mile sojourn around the USA
Thanks for the input.
Old 10-30-2019, 11:42 AM   #6
Fully charge the battery then disconnect a cable. It will be fine for the next 4-5 months.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank (Two-GC2) - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
2009 F150 - 5.4 Litre with Tow Package
Boon Docking 99% of the time.
boondocking is offline   Reply With Quote
Old 10-30-2019, 12:25 PM   #7
Again... are you planning on leaving the refrigerator running?
Or... are you shutting everything down?
Old 10-30-2019, 01:15 PM   #8
I pull my battery and trickle charge it on my home work bench during the off season.
Roberte52 is offline   Reply With Quote
Old 10-30-2019, 01:37 PM   #9
I fully charge my batteries then completely disconnect and left them outside until spring, then they get topped up. They lose less than 10% charge over the 6 months of winter.
2007 Surveyor SV230
Old 10-30-2019, 01:44 PM   #10
X2
I do as well... BUT... the OP mentioned the refrigerator in the original post being on 12v... until they answer the question I have asked twice... we really can't give them an answer whether to disconnect the battery.
They said they have no power at storage but mentioned the refrigerator on 12v.
Sounds like they either need to keep it plugged in or disconnect with no refrigerator.
Awaiting more information...
Old 10-30-2019, 02:17 PM   #11
NJKris's Avatar
That fridge thing is pretty cryptic. But he's probably pretty fried traveling 12k miles, lol.
Old 10-30-2019, 08:37 PM   #12
Shutting everything down.
Concern is how much draw the LP detection unit will dtaw
Old 10-30-2019, 08:38 PM   #13
Will disconnect battery and turn the frig off
Old 10-30-2019, 10:01 PM   #14
Great, thanks.
Just make sure the battery is fully charged, then disconnect. You'll be fine for 4-6 months.
Old 10-30-2019, 11:14 PM   #15
Since it is not as cold in Florida as a lot of the country, just give it a check with a meter every month or so.
Trojan recommends that the battery should be charged once it gets to 70% down(12.37V) in storage. I would only let it drop to 80% max myself.
babock is offline   Reply With Quote
Old 11-06-2019, 07:18 PM   #16
Hugeez's Avatar
Take the battery out. We take ours out when I winterize and put it on a trickle charger until spring time.
2018 PUMA 31 BHSS
2017 RAM 2500 LARAMIE 6.4 HEMI 4X4
E2 WDH
Troy, Josie and our 2 K9 co-pilots Breck and Maggie
USN 86-92
3 nights camped so far in 2020
Hugeez is offline   Reply With Quote
Old 11-06-2019, 07:27 PM   #17
Tks dir tks info.
Will do.
battery
