Old 06-24-2024, 01:03 PM   #1
Bedroom Fan
Hello Everyone,
I would like to put a fan in my bedroom where the tv goes on the wall. Any Ideals on a good quite fan. It has to be light weight because i will mount it on the TV backer part of the wall.
I have a 2021 Forest river ultra lite camper Thanks very much
gschneider12 is offline   Reply With Quote
Old 06-24-2024, 01:55 PM   #2
RV There Yet?
IsleDog's Avatar
depending on the size of the fan you want, i would highly suggest the RYOBI Whisper fan. lots of fun ways to mount it and it is dual powered, so you can run it from a wall plug or you can use a battery with it. VERY quiet and moves a nice amount of air. nice to have a battery fan to move outside or to turn on while in the RV while disconnected from shore power.
what are your requirements for a fan? do you want to use it while traveling (like stopping for lunch) or will it only be used/needed on shore power? is the outlet on an inverter and you have power anytime you want/need it? all of these things will change the answers you get.
2018 17RP
2009 Crew Cab King Ranch F150 "Goose"
IsleDog is offline   Reply With Quote
Old 06-24-2024, 02:01 PM   #3
Chuck754's Avatar
I realize this is an old post but in case you have not found a fan for your bedroom I would suggest looking at an 18V Ryobi fan. They are super quiet work fans which can be run on a lithium battery pack or on an extension card to a 110 outlet. Very portable and a great size for camping. We use it in our bedroom plugged into an outlet but we also use it outside on the picnic table with a battery pack. Nice thing ours stores in the cabinet under the kitchen sink with the toaster and coffee maker. . Ryobi tool and accessories are featured at Home Depot but you can find them at Amazon for about the same price. Here is a link https://a.co/d/02KqzYTU.
If you want to use a wall bracket you could probably mount a TV bracket on the bottom of the base.
HAVE MINI WILL TRAVEL!
Chuck754 is offline   Reply With Quote
bed, bedroom, fan, roo
