We have an older Coleman Black Cat catalytic heater we've used in our TT's for a number of years. Our previous TT was a hybrid so there was plenty of air exchange in it. Our current TT is a normal trailer and seals up fairly well. We've always left a window cracked as well as the ceiling vent when using this heater and have never had the CO alarm go off.
As we are nearing retirement and camping more, we figure there will be more boondocking in cooler weather so I'm wondering if we need to look at other heaters. I have researched the
Mr. Heater and it says for indoor use. There is also the
Camco Olympian Wave heater that says it's safe for indoor use. Neither of these heaters says they are catalytic heaters.
The reason I think that is important is because after reading up on catalytic heaters (and if I understood what I read) they actually DO NOT produce carbon monoxide through their chemical reaction process. To be an actual catalytic heater there is supposed to be a metal (platinum) component that is the catalyst. None of the products I mentioned above mention having a platinum component and in the case of the Camco and Mr. Heater they don't even use the word catalytic.
So that leads to the question - are any of them truly catalytic - zero CO emission heaters? The Camco heater is certainly expensive enough to have a platinum catalyst but again, they never mention it. Our Black Cat was only about $50 if I remember right and I believe they are no longer made/sold.
I just want to be warm and safe!
