Big Surprise with gray tank
I pulled the coroplast of the TT this morning it took two of use about 1.75 hrs. it was screwed and stapled. As I expected wires were hanging loose. I did find holes in the duct work and one run crushed. The big surprise was my gray tank for the shower had the center support bracket hanging loose and had been that way from the mfg. the way the bracket mounts it has to be in place prior to the floor being installed somehow it was missed. I did get it in place by bending the attachment end and sliding the bracket all the way to one side then holding up on the tank putting it back on the rail and sliding it to the original position. the bracket is for keeping the tank from bowing not holding it in place. Glad I pulled the under belly. Oh ya no insulation anywhere.
Retired Navy
2016 Flagstaff 26 FKWS
