Old 05-18-2020, 01:27 PM   #1
Santabobswife's Avatar
Birds in RV Barn
Our RV barn is open. Shortly after building it, we started having some birds. We got a couple of plastic owls and mounted them....some help, not completely. Then we purchased a LOT of rubber snakes and put them in the eves. Seemed to help a lot. Then, here they came again. We put up wind chimes and that really helped for a while. NOW, this year the birds are back in multiples. I think every one that was ever born near is now nesting in our RV barn. It looks like a bird outhouse.
Any suggestions?
Santabobswife
Bob, Diane & Snoopy
2018 3050s Sunseeker
Santabobswife is offline   Reply With Quote
Old 05-18-2020, 01:58 PM   #2
Multi-Slacker
My dad had lots of problems with pigeons in his barns. He ruined my boyhood .22 by using birdshot in it. I used a pellet gun (ammo is much cheaper) and shooting it is likely to be legal. Also had a huge problem with bats - which totally freaked my wife so I spent a day shooting bats with the pellet gun. YMWV
Safe Travels
CurtPutnam is offline   Reply With Quote
Old 05-18-2020, 02:00 PM   #3
FordHauler's Avatar
I used bird netting stapled to the bottom of trusses in my previous outbuilding. Google bird barrier to get lots of things to consider
Travel safe
2019 Ford F-350 Super Duty CC Dually 6.7 Diesel
2011 Cedar Creek 36CKTS Touring Edition
I Catch Fish......What is your SuperPower?
FordHauler is offline   Reply With Quote
Old 05-18-2020, 02:13 PM   #4
We had problems with ducks getting in our pool. We strung fishing line from pvc poles along the edge of the pool on the side they came in. No more ducks..
I would string across from rafter to rafter. Or put several strands a foot apart around the perimeter of your barn. Birds don’t like objects that damage wings..
You see this is a lot of waterfront restaurants...
dalford is online now   Reply With Quote
Old 05-18-2020, 02:46 PM   #5
Cyote61's Avatar
There is a poduct called Preditor Eyes that we've used in several places and it really works. Its a big yellow blow up ball that has big foil eyes on it and u just hang it up under the shed. Not expensive and really does work. Barn swallows are one of the hardest nastiest birds to run off and it even got rid if them in one place we had. Should not be hard to find one. Just checked Amazon and they have a three color package for 17.50. We've only tried the yellow one.
cyote61
DX3 36 TS 2018
Cyote61 is offline   Reply With Quote
Old 05-18-2020, 02:54 PM   #6
Never heard of it, but we don't have a barn either.
Is this it? https://www.walmart.com/ip/Visual-sc...hoC0-kQAvD_BwE
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 05-18-2020, 03:59 PM   #7
The Driver
PoppySteve's Avatar
We had Martins in a Live Oak tree next to my office building. Very beneficial birds, but leave the worst mess. They tried everything to move them along. The only thing that worked was bird net to keep them out of the tree. Mist net I think it's called.
Steve and Barbara
2011 Sunseeker 2860
2006 Honda CR-V
PoppySteve is offline   Reply With Quote
Old 05-18-2020, 04:05 PM   #8
Boss Ox & Drovergirl
oxcamper's Avatar
Go organic and natural:
CATS
(we have about 17 barn cats looking for a good home)
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2016 GMC 3500HD Duramax dually
1992 Goldwing Aspencade
oxcamper is offline   Reply With Quote
Old 05-18-2020, 05:41 PM   #9
Multi-Slacker
We had a herd of barn cats too. The pigeons were way too high and therefore too much work when there were a gazillion rodents running around.
Safe Travels
Old 05-18-2020, 05:50 PM   #10
CincyGus's Avatar
Most of the snakes/owls/predator things work initially and then the birds get used to them and realize they are of no threat.
Netting is the cheapest solution, building a ceiling so there are no roosting spots is the other. I've seen plastic sheeting using to cover up access but it doesn't hold up for more than a season or two. Maybe a tarp nailed up and covering access as a longer lasting solution.
Otherwise, get the pellet rifle out and zero in the scope.
2020 Chevrolet 2500 LTZ, 2019 Forest River Wolfpack 23Pack15, 2014 EZGO Golf Cart.
CincyGus is offline   Reply With Quote
Old 05-19-2020, 07:13 AM   #11
Cyote61's Avatar
Yes that's it! You don't need a barn to have barn swallows. And overhang and they will build a mud nest asap. The mud is very hard to clean off.
cyote61
DX3 36 TS 2018
Old 05-19-2020, 08:10 AM   #12
I used these in the rafters of the hay barn above our TT. Because of the rafter height, I fixed them to 1x2's on the shop floor, then secured the 1x2's to the top of the rafters. Protected the top of the trailer from roosting bird droppings, but not from the fly-by attackers (and I think some of them made a game of it!) Good luck.
https://www.amazon.com/Bird-X-Plasti.../dp/B0019F8IX6
Greg 'n Deb
2020 R-POD 195 HRE
'17 Tacoma 3.5L,'07 Tundra 5.7L w/ tow pkgs.
Dirt Sifter is offline   Reply With Quote
Old 05-19-2020, 01:53 PM   #13
Any suggestions?
I just had a carport built last fall, 30x40, and the birds started coming in recently. I put plastic owls around, worked for a little while. I bought some reflective stuff and some with eyes from amazon. Hope that works. From what I am reading, blocking the places they go may be the only way. This was built to hold an RV, walls are 14', dang, that won't be easy.
Anybody try the light weight owls/birds of prey that hang on a string and are supposed to move in the wind?
Jeff
2016 APEX 215rbk
2016 F-150 4WD 3.55 3.5l ecoboost
jwfrede is offline   Reply With Quote
Old 05-19-2020, 02:38 PM   #14
I have had good success on my houseboat with mylar bird tape. Lots of reflections with minimal air currents. They use this in agriculture.
aircommuter is offline   Reply With Quote
Old 05-19-2020, 04:01 PM   #15
Vince and Charlette's Avatar
Just completed a 24x56' pole barn to house our camper. Anticipating a problem like yours, I had metal soffit all around and eave insulation with insect netting. It cost more for these things, but we didn't want to chase these issues for the rest of our lives on earth! Unfortunately, we have boring bees...about the size of the end of your thumb. Thankfully, they don't sting. But believe me, they can destroy a 2x4' beam in a few years. They come back year after year and use the same holes which twist and turn inside the wood longer and longer each year. Nothing (legal) kills them. "Bee Box" catches them but not very effective. Catches one or two a week while there are a hundred or more around the house and our nearby farm equipment barn.
2018 Berkshire 38A
Vince and Charlette is offline   Reply With Quote
Old 05-19-2020, 04:09 PM   #16
mjones12's Avatar
Any suggestions?
One suggestion: check your air conditioner before next trip. Ours quit working but was fine after dealer charged us $135 to take the cover off and remove a bird nest. A 5-minute job.
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
mjones12 is offline   Reply With Quote
Old 05-19-2020, 05:22 PM   #17
Try Bifen on the ares where those bees hangout.
Old 05-19-2020, 05:56 PM   #18
I use bee traps from amazon, they work great, but price is double what I paid a year ago.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Jeff
2016 APEX 215rbk
Old 05-19-2020, 05:57 PM   #19
Homebrew's Avatar
I have a bird issue in my Carolina carport.
This has been the worst year ! Thinking about removing the facia/ soffit trim piece to prevent the nesting.
XLR Thunderbolt 300X12HP
2014 Ram 3500 DRW
Homebrew is offline   Reply With Quote
Old 05-19-2020, 06:22 PM   #20
I have an enclosed RV garage where the birds have destroyed the fiberglass screens that cover the round air holes, to nest I keep covering the screens on the inside with thin plywood. I really need to re-screen with stainless steel mesh. The problem is that it is 19' high on the outside.
Ram 2500 / FR Surveyor 251rks
debit is offline   Reply With Quote
