Old 06-19-2016, 12:09 PM   #1
Black Tank
2013 sp296 Surveyor. My bath tub drains into the black tank. Is this normal?
mmathot is offline   Reply With Quote
Old 06-20-2016, 07:36 AM   #2
Traveling Two
jerryliving's Avatar
I wouldn't think so. How do you know?
jerryliving is offline   Reply With Quote
Old 06-20-2016, 07:53 AM   #3
Insert witty title here
It's not common but some RV's do that.
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
timfromma is offline   Reply With Quote
Old 06-20-2016, 08:07 AM   #4
SeaDog's Avatar
I would not think this to be the case. They are on two different systems. They may share a common (isolated by valves) drain pipe. What makes you think the tub drains into the black tank?
Retired Navy
2016 Flagstaff 26 FKWS
Old 06-20-2016, 08:31 AM   #5
On some units the shower/tub (grey) runs into the black tank.
Somewhat uncommon but it does exist.
Another possibility is... most units use a common sewerage dump port. If the grey dump valve is open and the black dump valve is partially open or defective, grey water could theoretically be getting into the black tank that way. Slim chance but a possibility none the less.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 06-20-2016, 08:34 AM   #6
VinceU's Avatar
Black Tank
In the case of two of my class C units, one had bath sink m/t to Black and the other had bath/shower m/t to black. Based on ease of piping in tight area
black, black tank, tank
