Old 09-19-2021, 08:57 PM   #1
Black tank showing 1/2 after emptying
I recently bought a 2022 Cherokee Alpha Wolf Limited bunk house.
Its one week old Im living in it till my house is repaired due to Hurricane Ida. anyways I Have emptied my gray tank several times when reaching half and had no problems. My black tank finally got to half so I decided to empty it after doing show its still showing half. Ive only used it for number 1 it has never seen number 2 so its only liquids. Why is it showing half after emptying?
alexfire is offline   Reply With Quote
Old 09-19-2021, 10:05 PM   #2
You can try filling it back to 1/4 or more and add 1/4 Dawn Dishwashing liquid and driving 50 miles or more. That is, if you are sure it really emptied.
AbdRahim is offline   Reply With Quote
Old 09-19-2021, 10:09 PM   #3
bikendan's Avatar
Tank level indicators are notoriously inaccurate. They are simply bolts put in the side of the tanks.
Old 09-19-2021, 10:11 PM   #4
I find using the black tank flush, if your trailer has it, as the best way to get it back to showing empty.
2021 Cedar Creek Cottage 40CRS
Victron MultiPlus-II 12/3000/120-50 Solar installation
SacRV is offline   Reply With Quote
Old 09-19-2021, 11:22 PM   #5
If you have a tank flush. I bought a water meter and I put in 10 gallons of water, then open the black tank and let it drain. I do this 2 or 3 times and then my guage shows empty. Then I close the tank put in 5 gallons of water and add my chemicals and good for awhile.
jmcclocklin is offline   Reply With Quote
Old 09-20-2021, 10:46 AM   #6
ignore them ....
As already said, the tank lights are unreliable, our fresh tank showed 2/3 full the day we picked up our brand new Micro Lite 25KS(tank was empty), ... even if they are working perfectly, when the black tank light shows 2/3, you/I don't know how close it is to completely FULL, with our 30gal tanks it could be another 10 gals or it could be just one more 8oz flush before the FULL light comes on, you don't know, ... I don't trust um and don't look at um, ... the fresh water tank is translucent so I can look under the trailer and see its level, ... I know the gray water tank is full when/if it shows in the shower(it's gray water, no problem), ... our toilet has a direct look into the black tank, looking down into that tank is the surest way to know its level, but when you open the toilet valve to see, the water flow prevents getting a good look, so installing a shutoff valve on that water line solves that and is beneficial in other ways, ... if you ever get a leaking toilet valve, that shutoff valve will allow you to stop the leak and give you control over that issue until you can get it fixed without having your campground stay interrupted, or if boondocking where water control is utmost important, you have complete control over how much water the toilet uses, .... that is just my take on those LIGHTS, .... pics are of the shutoff valve I installed, ....
ID:	263106   Click image for larger version
ID:	263107   Click image for larger version
fella10 is offline   Reply With Quote
Old 09-20-2021, 11:08 AM   #7
Part-Time Campground Host
cboss's Avatar
I do like that mod. Thanks for the tip!
Craig & Cath
Days camped since 2015(retirement): 1687
cboss is offline   Reply With Quote
black, black tank, show, tank
