Old 08-22-2019, 07:27 PM   #1
Exclamation Black Water Tank 'pull' stuck closed
My 'black' water tank pull won't open. It has always worked before without any problems. I'm afraid if I try to force it by pulling really hard I may break something? Any body have any suggestions? The tank should be almost empty, but my gauge is showing full. Would pouring a bucket of 'hot' water down the toilet help free it up or just fill the tank further? I should add that I have a 2016 Cedar Creek 34RE 5th Wheel.
rrolphe is offline   Reply With Quote
Old 08-22-2019, 11:25 PM   #2
Riverbc's Avatar
You could try a drain valve lubricant.
ID:	213129Click image for larger version
https://i.imgur.com/t6krhfM.jpg
Riverbc is offline   Reply With Quote
Old 08-23-2019, 02:35 AM   #3
You could also do the pull it a little push it pack pull it a lottle push back. Has it been awhile since you used it. Could just have some dried uhh stuff stuck to it if its been awhile.
AceCombat is offline   Reply With Quote
black, black water, tank, water, water tank
