Originally Posted by Dkdickerson
We just purchased a 2019 Crusader 341RST and will make our first long road trip next month. My question is, if we stay in areas that have sewer connections and empty every morning, do I need to put the black water treatment in every day? Or should I not dump until the tank starts to get full.
As mentioned, waiting until the tank is 3/4 to almost full is better to empty the contents. (solids & liquid)
Remember... it is a HOLDING tank and not a septic tank so things simply won't break down in the short time using it. The solids will flush out better when the tank is fuller.
Also as mentioned, if you only stay a few days and plan to go to another park within a few days to a week, there is no need to empty the tank for travel if you choose not to. We often go several weekends in succession and never dump the black tank until the last trip before not going for a while.
We have always had good luck using the Geo Method (Google it) using Calgon© liquid water softener (available at Wally World) along with Dawn dish washing detergent. We also usually put some Thetford Aqua-Kem© in for odor when we leave stuff in for several weeks. (or any chemical of your choice)
Should you decide for some odd reason you do want to dump every day (I wouldn't do that) the need to put chemicals in would be moot. Unless it's 100º+ outside, one day worth of chemicals is wasteful. But be sure to add water to the tank before dumping. (also wasteful)
