Old 04-02-2021, 02:22 PM   #1
Steve from Maine
jaudet71's Avatar
Boondocking pump to fill fresh tank.
Hello all. After reading a post about filling your fresh water tank without pressure.... such as when boondocking. I think it was Titan Mike that described his set up and inspired me to go this route.
First I got an RV pump that is identical to my current RV pump. That way I have a spare if needed.
I put on adapters to use garden hose fittings with quick connects.
I installed an automotive style outlet in my water/sewer bay.
I also have the option of clamping to a battery if needed.
I mounted everything on a plaque with an on/off switch.
I got a 30 gallon bladder for the back of my jeep toad.
Below are the pictures of a test out of a 5 gallon jug. Worked like a charm. This keeps more boondocking options open. The bladder folds up to the size of a couple magazines.
Hopes this helps somebody out. Let me know if you have questions.
thanks Titan Mike.
ID:	251027   Click image for larger version
ID:	251028   Click image for larger version
ID:	251029   Click image for larger version
ID:	251030   Click image for larger version
ID:	251032   Click image for larger version
ID:	251033   Click image for larger version
ID:	251034   Click image for larger version
Retired UPS Driver
2015 Georgetown 270s
960W solar, 60a Renogy MPPT, 510ah Li
10CU.F GE dc only fridge
2019 Jeep Wrangler Unlimited
2008 Yamaha WR250R
jaudet71 is offline   Reply With Quote
Old 04-02-2021, 03:43 PM   #2
Always Learning
Very nice!
Old 04-02-2021, 05:18 PM   #3
Nice. I have been considering building something similar
2021 Flagstaff 21DS
2015 Silverado 2500HD (overkill but convenient)
Renogy bits: 3000W Inverter/Charger, 400Ah LiFePo4, 40A DC-to-DC
Rich Solar bits: 400W of panels, 40A MPPT
Misc bits: LevelMatePro+, SolidRemote based wireless controlled LED storage lighting
jbflag21ds is offline   Reply With Quote
Old 04-02-2021, 05:36 PM   #4
robo44's Avatar
Looks very similar to mine, All in all looks great!
2019 FR3 33DS Motorhome
650 Watts Solar, 400Ah LIFEPO4, 2000 Watt Inverter, 40A DC/DC Charger, SumoSprings, Roadmaster Steering Stabilizer, BlueOx Trac Bar, Truma AquaGo WH, NVIDIA Shield TV
Days Camping
2019 57:2020 20:2021 30:2022 46:2023 9:
robo44 is offline   Reply With Quote
Old 04-02-2021, 06:05 PM   #5
Originally Posted by jaudet71 View Post
thanks Titan Mike.
You're entirely welcome. I can't really say the idea was mine originally as I think I read about using the same pump as in the RV on another forum.
Glad to see that others are benefitting.
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 04-03-2021, 08:23 AM   #6
Mine is similar, except I have installed a female cord end off the batteries. Then since our solar panel, from our last trailer, has a male cord end on it, I built a male cord end to a quick disconnect for a spare pump. This way I can use a regular extension cord to get my pump to the back of the trailer, where our water connection is, or if we're using the solar panel, it can be moved out of the trees into the sun.
I also built a set of clamps for the same style of quick disconnect. That way I can lend the pump set-up to another camper to help them out.
Camped: 2022 (Days/Nights) - 41/33
2021 (D/N) - 37/29, 2020 (D/N): 58/49, 2019 (D/N):27/20
TT: 2020 26' Hemisphere 26BHHL
TV: 2020 GMC 2500HD 4x4
glen1971 is offline   Reply With Quote
Old 04-03-2021, 08:52 AM   #7
gooiebob's Avatar
When we went to state parks alot I just bought a spray tank from Harbor Freight and changed the hose, then used my onboard battery to run it. Worked great. I think it was a 15 gallon and I could fill the tank in two trips.
Bob
2019 Della Terra 29k2s
2014 Toyota Tundra 5.7
gooiebob is offline   Reply With Quote
Old 04-04-2021, 01:37 PM   #8
mlmay12's Avatar
Very nice job. I did something similar with an old pump from a camping shower. I like the idea of using the same pump as your RV as that gives you a spare. Think I will look at that : )
Name:	Water Pump_1.jpg
2016 Dynamax Isata 3 24FW
2016 Jeep Willys JK
Yellow Lab Buddy Biscuit Eater
USN-RET/DOD-RET
mlmay12 is offline   Reply With Quote
Old 04-04-2021, 06:43 PM   #9
Recently new!
Paulie1138's Avatar
Send a message via AIM to Paulie1138
While I did get an upgraded pump for my RV, I have yet to install that. I am currently using the onboard pump with a diverter valve. Valve is on the suction side of the pump. It switches between the main tank and an additional hose that I can put into whatever water jug I happen to have. I then wired in an additional power switch to the pump in the water bay. I put the outside shower hose into the water fill port if I need to fill the onboard tank, or shut off the pump and use the inside pump switch as normal, and draw the water from the outside water jug. My plan is to put the upgraded pump into the camper, and use the old one for water duty. Setup I have works so far! Sounds more complicated than it actually is. The best thing i did, was to add some split air conditioning pipe foam over the water lines wherever they pass thru the floors and walls. Put the pump on a piece of plywood with a rubber mat. Cut down the pump noise a bunch. Some have added the accumulator tank, which is going to be one of my next mods. I should change out the pump while I have everything apart!
1987 Starcraft Nova tent trailer, purch. '87, sold 8.14
2013 Crusader 290RLT bought new, 8.14 lotsa mods!
2001 Ford F-250 7.3
Loving wife, R.I.P., 6/6/19
and Mason the always dirty dog! R.I.P, 2/19
Paulie1138 is offline   Reply With Quote
Old 04-05-2021, 03:41 PM   #10
Steve from Maine
jaudet71's Avatar
I did consider of that kind of set up using the outside shower. My next trip is going to be about 19 months and liked the idea of an extra pump on hand. I also decided to keep everything involved to one side(the water bay side). I also use the electrical outlet for my compressor as my air tank is two doors down.
A lot of good ideas here.
Retired UPS Driver
2008 Yamaha WR250R
Old 04-06-2021, 08:42 AM   #11
We carry a 20 gallon stainless steel stock put with a ball valve on the bottom. It’s sold for beer brewing but we use it for doing large boils, boiling water for dishes and such.
I thought about the 12v pump but I couldn’t justify the costs of the pump vs a 120v bilge pump.
I need shore power or generator. Never leave home without the generator anyway.
This allows me to put the stock pot in the back of the truck and bring about 10 gallons of water to the trailer., granted we aren’t going off-roading to get from the water to the trailer. Just some gravel roads at worse.
Pot never leaves the truck when full.
quicky06 is offline   Reply With Quote
Old 04-06-2021, 11:31 AM   #12
zipmart's Avatar
This was my solution. Purchased an inexpensive 12v water pump and mounted it close to the Fresh Tank Fill port. Clear tubing from the hardware store and appropriate adapters enables me to monitor the transfer process. Tapped into the wiring for the LED light in the bay to provide electrical power. Not necessarily high volume, but works well enough.
The way I see it, you can either work for a living or you can fly airplanes. Me, I'd rather fly. Len Morgan
2018 FR3 29DS
TOAD - 2002 Toyota Tacoma 4WD
zipmart is offline   Reply With Quote
Old 04-06-2021, 11:55 AM   #13
RV There Yet?
IsleDog's Avatar
Bob
we bought a 25 gallon sprayer tank with pump just for this purpose. fills our tank in one trip and either clips to a battery or plugs into the 12v socket. it gets sanitized and winterized just like the campers tank and pump. we adapted the hose to use garden hose connections. at just over 2 GPM it takes about 10 minutes to transfer.
2018 17RP
2009 Crew Cab King Ranch F150 "Goose"
IsleDog is offline   Reply With Quote
Old 04-06-2021, 02:25 PM   #14
Steve from Maine
jaudet71's Avatar
Zipmart.
I like the mounting. Maybe if I take off the top cover piece like you have I would have room. Thanks.
Retired UPS Driver
2008 Yamaha WR250R
Old 04-06-2021, 02:43 PM   #15
Chuck_S's Avatar
The onboard freshwater pump was extremely noisy so I replaced it with a "whisper" type and mounted the OEM pump in a spare 12v battery box for use to pump water from the 35 gallon freshwater tank (from Tractor Supply) I put in the back of my Expedition when we camp without onsite water. Pump was "free" since the old pump was coming out regardless.
I put a female Bargman connector on the side of the battery box and plug the trailer's umbilical cord into it to power the pump. Toggle switch and some short hoses and it's done. Been working 15 years now although used less frequently as onsite water is getting more common at the state parks we frequent.
-- Chuck
Chuck_S is offline   Reply With Quote
Old 04-08-2021, 09:46 AM   #16
Steve from Maine
jaudet71's Avatar
Pump mounted
I now mounted the pump on the side wall of the water bay. I now need to get or make a very short section of drinking hose to go to the fresh intake. Also I used my 90 degree elbow from my city water so I need a couple more of those.
Thanks all for helping me improve my design. Every idea helps form our decisions whether we use it or not.
Retired UPS Driver
2008 Yamaha WR250R
boondocking, pump, tank
