01-31-2020, 10:09 AM
#21
Broken Toe
This was answered on Post #4.
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
"Camper" 2016 Rockwood Signature Ultralite 8329ss
"Casper" 2017 Ram 2500 Laramie Diesel
..ProPride 3P Hitch - "Yeah. It's worth it."
01-31-2020, 10:28 AM
#22
I have work for a cleaning co. ServiceMaster for yrs and they have a cleaner call Wall Glide and it took off ink and other stuff.There the biggest cleaning co in the world.So maybe you have one around you .All you have to do is miss 2 ozs per gal . Let us know what takes it off thanks
2019 Flagstaff 26 RBWS
2015 GMC Sierra 1500
2019 camp 17 nites. Bill,Alley and are two kids Sierra,Ivy. 2020 camp 9 nites
01-31-2020, 01:46 PM
#23
I am still sticking by my idea.
forest river will tell you "I meant to do that"
Here is what mine look like.
No RV currently
01-31-2020, 01:57 PM
#24
in this larger picture you can see where it looks like they taped the floor to paint it.
No RV currently
01-31-2020, 04:34 PM
#25
Originally Posted by KarenDLS
Does this area get sunlight? We have a vinyl decal on our truck to match the camper and the driverside one has turned purple from lack of UV protection being applied
Nope...no "bleaching"pink from the sun causing this.
ArkRVHog
2018 Forester Model 2801 QSF
Little Rock, AR
OTR 2022-52 / 2021-51 / 2020-29
2019-71 / 2018-49
01-31-2020, 04:41 PM
#26
Originally Posted by jim1
Sun fade? Do you keep the blinds open?
Nope...sun, even through the skylight, doesn't hit under the dinette!
ArkRVHog
Little Rock, AR
2019-71 / 2018-49
01-31-2020, 04:43 PM
#27
Tim
Not a wet subfloor/bacteria situation...see #14.
ArkRVHog
Little Rock, AR
2019-71 / 2018-49
01-31-2020, 04:46 PM
#28
TowPro...you have the "pink-o virus" too! As I previously stated, my great dealer shared they replaced the vinyl on a new unit under warranty with this same problem so yours should qualify. This ain't right...whether new or a couple of years old like mine...ridiculous. Please let me know what they do for you...or don't.
ArkRVHog
Little Rock, AR
2019-71 / 2018-49
01-31-2020, 05:39 PM
#29
call FR and ask them. they will probably tell you "we meant to to that" so people would see the change in elevation and not trip over it.
and from everything I have seen, and heard when calling FR direct on the phone, no more hacks will be working on my MH. if I don't like it it will get carpet or thin engineered flooring by me.
I already had to take apart and fix the leading edge on the dinette floor. the face was so crooked it was at a 33 deg angle to the floor.
The floor was short of the slide frame so Clyde just slapped the bottom vinyl on it at an angle and called it a day.
I removed it, cut a filler strip on my table saw, put it back together with the correct angle and it now looks much bette.
No RV currently
01-31-2020, 07:13 PM
#30
Well at least the factory does a good job the second time around.
01-31-2020, 07:27 PM
#31
OP,
Was the vinyl like that when you bought it? It seems to me like this was a surprise to you. If it changed over time, I can't imagine this was intended to highlight vertical surfaces.
2019 Heritage Glen LTZ 272RL
2018 Ram 2500 CTD
01-31-2020, 08:04 PM
#32
Originally Posted by IchLiebeBier
OP,
You are correct...this "discoloration" just began within the last week. One day everything is matching, the next day it is a funky pinkish color.
I really think it is a much delayed reaction (maybe 2.5 years after the coach build) reaction to the adhesive/glue used on the vinyl.
My dealer is submitting this to FR...we'll see.
ArkRVHog
Little Rock, AR
2019-71 / 2018-49
01-31-2020, 11:07 PM
#33
Bacteria stains. Disinfect ASAP!
02-01-2020, 12:05 AM
#34
Originally Posted by Wolverine 1945
After installing floorcovering for 25 years, I never saw a vinyl floor turn Pink,
Saw many turn Yellow, but none Pink,
left the floorcovering Bus in about 2000 !!!
Cover it with Carpet !!!
Carpet in an RV?! Not only no, but hell no!
2019 Silverado LTZ 1500 6.2L 10 Speed 3.42 Max Trailering Package
2018 Freedom Express 192RBS
2022 Highland Ridge Open Air Lite Range 17BH
02-01-2020, 10:33 AM
#35
I believe all Forest River TT have a 10 year flooring warranty. You might want to check that out.
02-01-2020, 11:14 AM
#36
Than enjoy the Pink Vinyl !!!
02-03-2020, 03:34 PM
#37
I've never seen one that doesn't have carpet in it somewhere.
02-03-2020, 03:56 PM
#38
I prefer carpet, but the kind that is bound on sides with sealed rubber backer. don't use the rough backed carpet.
Our first choice of a campground is the beach. Your going to get sand in your camper. with linoleum the sand scuffs your floor and grinds into it. with carpet the sand seeps down into carpet but if its rubber sealed back the sane stops in carpet. vacuum it or shake it out and your ready for another day.
No RV currently
02-03-2020, 07:22 PM
#39
I use a big carpet remnant in the living area, when the slides are out. I covers almost the entire area. I just roll it up for travel.
02-03-2020, 08:38 PM
#40
A lot of new trailers are carpet-free. My 192RBS has a little on the slideout platform, but none on the floor. My 130RBSE has zero carpeting.
