Old 05-05-2021, 06:03 PM   #41
Originally Posted by Larry-NC View Post
Yes. That was already mentioned in Post #25.
Sorry, not trying to step on toes. He only mentioned that he checked the fuses and was giving a reminder that relays are also involved too...
2021 Wildwood FSX 190RT Toyhauler
2016 Chevrolet Silverado LT 1500 Crew Cab 5.3l 6L80 3.42 4x4
mikeyk101 is offline   Reply With Quote
Old 05-05-2021, 10:24 PM   #42
I will keep you guys posted. Thanks again for the support.
TTnewbie is offline   Reply With Quote
Old 05-06-2021, 10:47 AM   #43
Update:
The mechanic just called me. He found a fuse that was blown that I missed. He replaced it and it blew out right away. He lifted the Yukon and found two corroded wires coming from the 7 pin connector. He repaired the wires and everything is good to go.
A big thank you to everyone that helped me out.
Old 05-06-2021, 11:00 AM   #44
NMWildcat's Avatar
Glad you got it fixed in time for your trip. Thanks for the update. Happy RVing!!!!
Scott and Liz - Southern NM
Old 05-06-2021, 11:01 AM   #45
Sweet! That's really good news. Thanks for the follow up.
Old 05-10-2021, 06:15 PM   #46
Harbor freight and several other companies sell magnetic trailer lights. They work fine, but it is a good idea to add some duct tape to hold them down.
bbells is offline   Reply With Quote
Old 05-10-2021, 06:45 PM   #47
The problem was fixed but thanks for the suggestion. I actually order a set from Amazon that I have to return.
Old 05-10-2021, 07:52 PM   #48
A Mile High & a Mile Deep
pcsdpo's Avatar
Originally Posted by TTnewbie View Post
Update:
The mechanic just called me. He found a fuse that was blown that I missed. [he] found two corroded wires coming from the 7 pin connector. He repaired the wires and everything is good to go.
At my age, maybe I should check myself for blown fuses and corroded wires . . . DW claims I'm not the brightest bulb on the tree and not all my lights work!
"I would rather wake up in the middle of nowhere than in any city on earth." - Steve McQueen
pcsdpo is offline   Reply With Quote
Old 05-10-2021, 08:33 PM   #49
bikendan's Avatar
The OP posted the solution, 4 days ago, 3 posts before yours.
Old 05-11-2021, 08:01 AM   #50
Nix
glad it's solved.
Nix is offline   Reply With Quote
Old 05-11-2021, 09:09 AM   #51
Moosehead Dad
Lesson learned
Happy Camping.
Now that you have learned so much from this experience, you will be much better prepared for lies in front of you as a RVer. You will need it.
Welcome aboard!
bbmuse is offline   Reply With Quote
Old 05-11-2021, 09:23 AM   #52
Originally Posted by boondocking View Post
Try some contact cleaner on the 7 pin plug. Spray it on and connect and remove the plug several times.
Seems to be a run on contact cleaner. Either out or ridiculous price. I’ll use wire brush and isopropyl alcohol.
IDguy is offline   Reply With Quote
light
